Question about Pool & Spa
Hayward Pool Vac keeps turning right more and twisting hoses.
New shoes, checked/confirmed gear box is working correctly, no broken teeth on any gears (including gear box), left all hoses outside for 24 hrs to "untwist them", 10,000 gallon pool. (Engineer by profession). I cannot seem to figure out why the unit turns way more right than left, thus twisting hoses, eventually causing unit to stay in one place
SOURCE: Hayward Navigator Pool Cleaner Will Not Move
The problem is that you have too much play in your drivetrain. You will need to check for movement between the pod and the a-arm and then between the a-arm and turbine. It would also be a good idea to check the turbine bearings. Find the loose fitting, worn part and that is your problem. As far as it not twisting on the end of the hose; this is most likely caused by the screen on the back of the unit being obstructed by debris or the gearbox assembly being jammed by debris that got through the screen or is just worn out. If you have any mechanical abilty you shoud be able to do these repairs yourself with the help of a downloadabe exploded diagram. If not call a pool repairman the parts are not really that expensive compared to the cost of a new unit.
Posted on Jan 29, 2009
  • 366 Answers
SOURCE: Pool cleaner only goes in circles; doesn't clean the whole pool
could be a number of problems. The most common problem is the turbine bearings have failed. You will have to disassemble it to check them. A fix is a turbine kit with A-frames. This kit has all the moving parts excluding the turn valve. If your cleaner is going around in circles and twisting the hose, its likely you have a bad bearing or so on either the turbine, a-frames or both.
Posted on Sep 15, 2009
  • 366 Answers
SOURCE: Hayward navigator (Gunnite pool) does not move.
you need to install a turbine kit with "a" frames. sounds like your bearings are bad either on the turbine, "a " frames, or both. A set of shoes would be a good idea as well.
Posted on Nov 18, 2009
  • 990 Answers
SOURCE: seems like the movement of the navigator causes the hoses to tan
It sounds like it is time to pull the head and take it to the shop for repair. They can pinpoint wear and will usually do the repairs in the store for a small shop fee or just the cost of parts. It sounds like an "A" frame kit and gear box. Other things can be worn at the same time.
Posted on Dec 10, 2009
  • 64 Answers
SOURCE: Navigator Pool Cleaner: When I run my hayward cleaner the hose twists up a...
You have either a bad or stuck gear box or a loose or damaged a frame bearing. The gear box controls turning and the a frame controls propulsion, but one bad bearing will cause the cleaner to move more in one direction, causing the hose to coil. You can hold the cleaner under the water by the top of the hose, and it should turn in all directions within a few minutes. If it doesn't, then it is the gearbox. If it does, then likely a problem with the a frames.
Posted on May 19, 2010
I have three nav vacs and two pools. each pool has a working nav vac and I keep one for a spare. Pool #1- the vac started turning only to the left and in 15 minutes the hose was completely twisted...
This is a common problem with the Navigator. If you grab the part sticking out where the lead hose attaches to the unit, you should be able to turn it fairly easily with your hand. This is the swivel that is supposed to keep the hoses from getting twisted. When you take the unit apart, you will find a large gear plate with teeth that controls the swivel action. All it takes is one leaf or small rock to jam this plate solid and then there is no swivel action and the hose twists. Leslies should have know all about this.
Aug 22, 2011 | Hayward Navigator Pool Cleaner
Gets stuck behind the ladder
It could be one of several problems with these pool cleaners: check your water flow and adjust if necessary, check for worn shoes and wings, make sure that you have proper hose length, and check for steering failure. Steering failure can be caused by several things. Make sure the rear screen in clean and free of debris. Make sure your cone gear is free and rotates smoothly. Check your gear box and clean or replace if necessary.
Dec 24, 2010 | Hayward Navigator Pool Cleaner
My Hayward Navigator fails to get out of corners and climbs straight up a wall and remains in this positon. I have adjusted the suction flow to no avail.
Check your shoes and wings to make sure that they are not worn and don't have debris lodged in them. Make sure that your hose is the proper length and doesn't have obstructions. It could also be a steering failure. To check for steering failure, make sure that your rear screen is clean, make sure your cone gears are free and clean, and make sure that your gear box is clean and working properly. It is common for these pool cleaners to have one of these problems. Also, make sure that you have the proper tension in your rear flap.
Oct 30, 2010 | Hayward Navigator Pool Cleaner
Only goes counter clockwise
With these pool cleaners, turning in only one direction is most likely the result of a worn shoe or wing. Check them for any wear or tear and replace if necessary. It could also be a partially blocked throat that has restricted suction and is hindering movement. Check and clean your rear screen. Make sure that your cone gear is free and rotates smoothly in all directions. In none of these troubleshooting tips correct the problem, it could be your gear box needing to be replaced.
Oct 22, 2010 | Hayward Navigator Pool Cleaner
May 16, 2010 | Hayward Navigator Pool Cleaner
Navigator Pool Cleaner: My Hayward pool cleaner just goes in small circles...
Check all of the following. Ones of these issues is probably causing your pool cleaner to go in circles. Let me know if these soultions don't work and I will be glad to offer more solutions, but I a think one of these might solve your problem:
1. You might not have proper water flow. Too much or too little pressure will cause this to happen. Check the pressure with your flow gauge and adjust if necessary.
2. Check for a partial blockage of the navigator throat. If you have a blockage, it could disrupt the movement of your cleaner. Clear blockage if necessary.
3. Check the shoes and wings. Damage or wear to them can disrupt your patterns of cleaning. If you notice that your shoes or wings are worn, replace them to correct the problem.
4. Check to make sure that your hose is not twisted. It should be clear of kinks, twists, and knots. Untangle if necessary. Laying the hose out in the sun will make it more pliable and easier to untangle if you need to do this.
5. Other things that could cause steering issues: check and clean the rear screen, check to see that the cone gear is is free and rotates smoothly, clean/replace/repair gear box, check pod connection, and check turbine and spindle assembly.
Hope this helps! Let me know if you need clarification or additional help!
Navigator only turns one way, twisting up the line
Try one of these soultions. If you try these suggestions and it still doesn't work correctly, let me know and I will offer some different ideas. With this brand of pool cleaners, troubleshooting is usually pretty simple.
1. You might have an improper water flow that is causing your trajectory to falter. To remedy this, check your water flow with a flow gauge and adjust as necessary. If you have too little or too much pressure, you cleaner will not move correctly.
2. Look for a blockage in the navigator throat. If you see one, remove it. A blockage on one side could cause the cleaner to only turn in one direction.
3. Check for worn shoes and wings. Replace if necessary.
4. Check and clean the rear screen.
5. Check to make sure that the gears are clear and they they rotate smoothly in both directions.
6. Clean, repair, or replace the gear box.
7. Check turbine and spindle gear assembly, as well as all connections, and make adjustments as necessary.
May 05, 2010 | Hayward Navigator Pool Cleaner
Hayward navigator (Gunnite pool) does not move. If I hold by hose, in water, suspended above bottom, the unit does not turn. Hose in good shape , valves in correct position. previous to this it was...
Nov 18, 2009 | Hayward Navigator Pool Cleaner
Navigator hose cntinues to twist
I would recommend replacing the gearbox. That's what controls the turning so, if it's not turning correctly, that's the cause. It could also be the hoses. You could change the order of the hoses and that might help.
www.cpo2go.com
Feb 22, 2009 | Hayward Navigator Pool Cleaner
Pool & Spa Logo
355 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
