Question about Samsung HL-T6187S Television
Parts Diagrams Light source location?
    Top Expert:
  • Samsung Master
  • 74,473 Answers
You're asking abut it schematic diagram I assumes. It is with me, but cannot send to you by this window, as it is in PDF. Check this site. There are some schematics related. http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
Tip
My LCD TV has sound but no picture.
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
on Apr 10, 2009 | Polaroid FLM-2632 Television
Refrigerator wiring diagrams
need more info , make of the fridge would help
Aug 16, 2014 | Refrigerators
Seat Alhambra 2000 1.9 tdi wiring diagram needed as the dashboard is almost totally blacked out.i've checked every fuse replaced or tested every bulb inc holder.Thank you VM if anyone can help
I usually get wiring details from the library,they have these HUGE books with the whole wiring diagrams,of course as long as your car's wiring hasn't been altered ,you'd be able to find your problem. You could see if the dealer's auto parts counter could give you a print of the dashboard wiring.
Feb 12, 2014 | Cars & Trucks
How to change spark plug bmw 540I
You need to remove plastic cover, then remove coils (1 per plug) then undo plug with 5/8" socket & extension. A really good source for parts & tech tips - BavAuto.com or Pelican Parts.com and if you need diagrams goto RealOem.com - you enter your vehicles indue and you'll have FREE access to all diagrams that factory has available
Mar 24, 2011 | 2009 BMW 5 Series
I have sound but no picrure
Oct 21, 2009 | Vizio L32 32 in. LCD HDTV
Sound no picture
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
Jun 08, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
My maxent TV has no picture and no sound
May 07, 2009 | Televison & Video
Sound but no picture
Apr 15, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Philips 32 LCD TV sound no picture
Mar 23, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Samsung HL-T6187S Television Logo
173 people viewed this question
Henry  Thomas
Henry Thomas
