Question about Crosley Dryers
Control panel does not respond on Crosley Dryer Model CDE4205AYJ
None of the buttons respond on this Crosley HE Electronic Dryer Model CDE4205AYJ. The control panel lights up but nothing else. The control panel doesn't have the usual knobs, but it has one of those electronic bubble-type switch panels, like the ones on many microwave ovens. I opened up the back of the top console the control panel is on and found a schematic and troubleshooting guide. It says how to access the diagnostic mode. Most times the buttons don't respond to get into diagnostic mode. The few times it did go into diagnostic mode (I could see a "d" on the display, as per the troubleshooting guide) I couldn't get past that point because the buttons don't respond. Do I have a bad control board, the one all the cables plug into? Could this be caused by a bad high limit thermostat, door switch or anything else? Thanks!
  • Crosley Master
  • 8,220 Answers
Don't you just love electronic controls. On the inside of the dryer is like it always was back in the day with mechanical timers. The same old problem the old ones had is the blower wheel slips and causes overheating or a ball of lint at the base of the filter chute. This eventually blows the FUSE. Their is 2 of them fuses so look close one is usually behind a shield out of sight and may have been overlooked. DIAGRAM
Posted on May 01, 2013
SOURCE: Follow up on an earlier problem
I have had the same problem over the past several months. Typically it would clear itself out (clear 8.8. on display) after several minutes. Today it reoccurred but this time it would not clear. I knew it was a problem with the control board. So I removed the control board and discovered that the capacitor for the 5VDC power had ?popped?. I replaced the capacitor and every thing worked! Hope this helps.
Posted on Apr 23, 2007
SOURCE: Whirlpool Calypso Dryer Electrical Problem
Problem resolved. Although the membrane control panel passed the diagnostic test, it was defective. Probably a low voltage conductor went to ground, allowing the buttons to operate but throwing the control board into error mode.
Posted on Nov 11, 2007
SOURCE: Maytag Electric Dryer - Control panel doesn't light unless door is open
I fixed my own problem...I took the extra 4th wire(green) and attached it to the dryer body...There is a screw with the word ground stamped into the metal above it. This is right next to the panal where the cord goes into. I just unscrewed it and put my cable there and the dryer works perfect.....These things need to have a detailed diagram on the dryer....
Posted on Feb 15, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Posted on Feb 19, 2009
  • 401 Answers
SOURCE: Frigidaire Dryer not drying clothes properly
TRY DISCONECTING THE VENTING FROM THE BACK OF THE DRYER THEN RUNNING IT .POSSABLE THE OUTSIDE FLAPPER STUCK?IM THINKING NOT THE DRYER. GOOD LUCK!
Posted on Jan 16, 2010
Can anyone tell me why my dryer just flashes and I can not turn it off or on?
Electronic components rely heavily on having a good ground connection. Without a good ground, Mr.Gremlin can make an appearance, anytime, anywhere.https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link may be of some help in a diagnosis.
Oct 23, 2017 | Kenmore Dryers
My crosley electric dryer won't start, model cde4205ayj
Many things can cause this problem . Main timer , door switch,over heat thermal fuse , broken belt ,main power breaker
Nov 04, 2015 | Crosley Dryers
Crosley gas dryer will not work
Probably caused by failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
May 30, 2014 | Crosley Dryers
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
Is there a reset code for maytage neptune MD55?
There is not a reset button but you have a control board that controls all the commands and functions on this model.
You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we can overnight the correct parts to you after we know what your dryer is not doing right.
We hope to get you drying clothes ASAP.
Thanks, Ella
Nov 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Sears elite he dryer stopped working
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
check door switch..onthejob
Jan 27, 2009 | Crosley CDE6000 Electric Dryer
Dryers Logo
111 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
