Can i hook up sound tech cx4c to anything besides a guitar amp
Can I hook up sound tech cx4c speakers to a older stereo receiver. I just picked up the speakers at a tag sale,I want to make sure they work before I go out and puck up a guitar amp.
4 Suggested Answers
SOURCE: No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Posted on Dec 29, 2007
  • 19 Answers
SOURCE: Centre Speaker No Sound
i can think of two things., you may need to do the update on your sound card and computer and make sure you have the correct codec's installed or also you may need to go to the web site of the makers of your logitech speakers and see if they have a common solution for this problem...... i also wonder if you should bypass the sound card and directly connect your speaker system to the out put port on your computer ..... give it a try what can it hurt .... if all else fails maybe there is a faulty wire in the speaker system ....... ahy ?
Posted on Jul 17, 2008
SOURCE: what is the wattage capacity of Sound Tech CX4C PA
SOUNDTECH CX4C 2-way monitor wedges (2).
380 Watts Power / 190 Watts RMS, Full Range 2-way, 12" speaker, 1" Compression Driver(horn). Carpet Covered, Pole Mount capable, 8 ohm.
Impedance - 8 ohm
Woofer Size - 12"
Magnet Weight - .
Voice Coil Dia. -
H.F. Driver/Exit - 1"/Compression
RMS Power Rating - 190W RMS(8 Ohms)
Dimensions - 18.5"w x 16"d x 27"h
Weight - 52(lbs.)
Posted on Jan 09, 2011
No sound when connect guitar
have you checked the speaker leads in the back to make sure they are hooked up> if so, you have power to amp? Volume knob turned up? is guitar cord good? (try it in a different amp , or check w/ an ohm meter) . Does the guiter have active pick-ups? If so, is battery good? and last, is the volume knob on guitar up" try all that and get back to me
Jul 18, 2014 | Behringer V-tone Gm108 15w Modeling Guitar...
I am trying to hook up a RX-B503 amplifier to my KAWASAKI receiver. I have taken the output of the KAWASAKI to the input of the RX-B503 but I'm not getting any sound. I have talked to tech pro and they...
You're already playing around with it and trying to blow it up. Amps/receivers never feed back into other electronics in a continuous loop back to themselves. What 'output' were you trying to run to the the unspecified Kawasaki? Speaker, Tape Out or Pre-Out?
The RX-B503 is a receiver, so it has its own sources.
You don't say what you're trying to accomplish with the Kawasaki. Is it to drive more speakers, slaved to the TechPro, which is stereo-only by the way?
Use the Preamp OUT on the TP for volume-controlled STEREO programming to anything downstream.
Do you even have manuals for any of this?
Jul 13, 2011 | Audio Players & Recorders
I like the sound of my practise amp but it's not powerful enough can i connect it to a larger amp without getting feedback/distortion?
you can use the record outputs to run the signal into a stereo receiver without problems, though it would likely sound better with a shure sm57 microphone hooked up to a mixing board or other instrument amp.
the record output should be PERFECTLY balanced to hook up to a consumer-level stereo reciever with NO distortion; however, this record output might be too loud for another instrument amplifier or a mixing board; hence, the microphone in the latter situation.
short answer- "yes, but..."
Nov 26, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
What is the wattage capacity of Sound Tech CX4C PA Speaker? yeah! brand: Sound Tech/ model CX4C. thanks..
Impedance - 8 ohm
Woofer Size - 12"
Magnet Weight - .
Voice Coil Dia. -
Weight - 52(lbs.)
Aug 31, 2010 | Sound Design Lifeworks Technology iHome...
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I am looking to upgrade my receiver to an audio video receiver that will hook up to a blue ray via HDMI. I want to use my 901's forthe front speakers. Can you recommend a mid priced (<$600) AVR that...
Good day,
Congrats on your new AV receiver. I own an awesome Yamaha mid-priced AV surround sound system with HDMI, BR disc player, and all that stuff. However, I'm old school and use my 901 Series Vs with a Yamaha RX-797 'two-channel' receiver. To get to the point, I have some bad news. Mid-priced (mp) AVRs, or any AVR for that matter, will not work with 901s because the active equalizer (EQ) requires either a 'tape monitor loop' or 'pre-out / main-in' connection to work properly. You've probably been told the 'why they won't work' by now and it is very true--I know from experience. Most of today's AVRs do not include a 'tape monitor loop' or 'pre-out/main-in connection for the EQ connection, thus, killing all hopes of using 901s. I truly love my 901 Series Vs (since 1985 and still kicking) and love true 'stereo' for playing my music. Again, 901s are useless with today's AVR equipment (as I know it). Just don't let your 901s collect dust--they are truly marvels!! Go with a set of good 'standard' speakers for the AVR system and buy yourself a decent stereo receiver or amp for the 901s--that's how I do it!! I've tried Onkyo, Rotel, Sansui, Poineer amps / receivers--all of them. I can tell you this--for the common, working man/woman, nothing, I mean nothing available can match-up with Bose 901s like a Yamaha RX-797 (200W)--not to mention the sound quality-wow!!! And this unit is very reasonably priced for such awesome performance and high quality build. Just know that all is not lost. You can still use your 901s--I cna't listen to music without mine.
Aug 24, 2009 | Bose 901 VI Main / Stereo Speaker
Kenwood kdc x915 cd player
Hi there JT,
An Amp makes existing sound louder. If you aren't getting sound now, there's a problem.
From your description, it sounds like your stereo is going through all the motions, it looks and acts like it is functioning. Just no sound.
If that is wrong, let me know.
When you turn it on, do you hear anything from the speakers? White noise, a click, anything, any indication that they are hooked to any kind of power supply?
Let's do the basics (easiest) first:
  • Mute is off
  • Balance and Fader centered
  • Volume up
  • CD in and playing
Still nothing? OK.
  • I need you to access the back of the stereo. (Sorry)
  • Yellow and red are power. Black is ground. The unit works so these are ok. Blue is to turn on a remote device like an amp. There may be an orange, ignore.
  • There are four sets of wire for the speakers. Colors are White, Gray, Purple and Green. One of each set is solid colored, the other has a stripe.
  • White and gray are front
  • Purple and green are back. Same page?
  • These are what your speakers should be hooked to. One set for each speaker. Are they?
  • Eyeball the connects, look for shorts, disconnects, etc.
  • Get a speaker and test it right there behind the stereo on one set after another. Anything? If so, you have a problem in the wiring not the stereo
That's enough for now. I'd hate to write a book and have you solve the thing in chapter one. Get back to me with the answers and results. Those results will decide the next course of action (Unless of course it's fixed by then, in which case let me know with a nice FixYa rating).
Mike
Jan 06, 2009 | Car Audio & Video
Back speaker sound
Why would you only hook up one speaker for the rear channel? in 7 channel stereo, all speakers have 100% signal sent to them as "stereo" in Dolby digital, rear speakers are for "effects" not dialog. like a plane flying past you or a car driving by, that's when you hear a rear speaker. It also needs to be placed behind you, not next to you or in front of you. Unless you are using zone 2 & 3 the receiver's surround back will work. if you only have left,right,center,sub & rear; the rear speakers should go to surround speakers not surround back. If you still have questions, post a comment and I can explain further. Hope this helps
Feb 04, 2008 | Yamaha RX-V2600 Receiver
No sound through speakers
are you using RCA outputs(the round red and white plugs)? if you are then your amp is not turning on and if you are hooking up speakers to your RCA's (low level) then you will not hear any audio the signal is to low. would need to know more about how you checked the ic power?? one could verify an output ic by hooking up an amp since the RCA audio signal is picked off just before the output. if the low level works but the speakers do not then you have a bad output. anything else an o-scope would be handy.
good luch stereo tech (genesisportland@hotmail.com)
Feb 03, 2008 | Alpine CDE-9881 CD Player
 Grubhead
Grubhead
