Question about Roper REX3614KW Electric Dryer
Frigidaire Laundry Center stops working after a minute or two!! Why??
I Have a frigidaire laundry center, and the dryer stops working after a minute or two. It does heats and everything but like a say after a minute or two stops working. Then, i have to wait 5 minutes or more to turn it on again. I have the specifications located on the inside of the back cover, so if it helps: Frigidaire 120/240 volts Hz 60 Motor: L1-N 7,0 Motor L2-N 5,0 Heater: L1-L2 3 Kw Model: LC-3 Serial: 80GF 0817 So my question is: what can i do to fix this? and also will my dryer work on 120 only and still heat?
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Posted on Aug 21, 2007
SOURCE: Roper Dryer heats for 5 minutes
Thanks for the reply........I figured out the problem........the type of vent hose I bought was metal flex.......(I hate those things.....when you start to install them if you're not careful they start undwiding and come apart before you can get them properly installed).....anyway, someone had pushed the dryer a little too hard up agains the wall and smashed part of the vent hose.....and that dent was enough to pinch the exhaust off, and consequently the overheat element would shut the dryer down.......unkink the hose, clear the exhaust, and back in business.......
illdixie
Posted on Dec 12, 2008
TheMobilian
  • 8220 Answers
SOURCE: my dryer takes 4 to 5 times to dry a load of
The heating element is either gonna work or not work. Some things you can check for is air restrictions.0a5e52c.jpg887c79e.jpgIf all of that is good and you still have problems your timer might be on the way out.dc16397.jpgIf the timer turns out to be ok AND all the components in it are fine then you could have an electrical problem. The motor runs off 120 volts or one side of the breaker. The heater needs 240 volts to fuel its powerful 5000 watt element. This ready gives the breaker a beating and cause the timer contacts to arc.692e900.jpg
Posted on Jul 27, 2010
TheMobilian
  • 8220 Answers
SOURCE: Model rgd4400vq My
The fuse is in tact then and the control is sending power to the gas assembly. the ignitor is workng and the flame sensor. So it must be those coilsthemobilian_333.jpgthemobilian_334.jpgThese coils are KNOWN to get hot and quit with age.
Posted on Nov 30, 2010
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
How do I replace the dryer belt?
Hello Philip, I appreciate your inquiry!
Based off the information you have provided you need help with replacing the belt on your Frigidaire laundry center. In order to access the pulley you would need to disassemble the laundry center. I would recommend seeking assistance from a professional technician for proper disassembly of your laundry center. Incorrect disassembly could cause personal harm or future issues within the laundry center. Best of luck! -Matt
Dec 15, 2015 | Frigidaire FFLE2022MW Electric...
Frigidaire Washer Dryer Combo (Stacked) We had to have the power shut off to our house. Now that it is turned back on, our washer dryer combo won't start.
Thank you for your inquiry, Caroline!
From the information you have provided your Frigidaire laundry center is no longer working. I understand that you had to shut off power to your house and now your laundry center is not coming on. It sounds like you could have a possible short within your timer. I would recommend performing a reset on your laundry center and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have issues with your dishwasher can you provide me with your model number? In order to locate your model number you can find the serial tag and that should be located on the inside wall of your dishwasher. I look forward to assisting you further. -OOS
Mar 23, 2015 | Koolatron 1.7cuft Thermoelectric Fridge
READ FRIGIDAIRE ERROR CODES
Hello Rob Olsen, I appreciate your inquiry!
I understand that you would like to have information upon reading error codes for your Frigidaire laundry center. I was able to locate a manual that has information regarding error codes for your laundry center. I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Nov 09, 2014 | Frigidaire FFLE1011MW White Washer/Dryer...
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
How to reseat the dryer on a fgx831cs dryer
Hi Amy, this is AP!
I understand you want to reset your Frigidaire gas laundry center, model FGX831CS. For this particular model laundry center I would recommend turning the breaker to the appliance off for 5-6 minutes, and then turn the breaker back on. This action will reset the laundry center completely for you. If you can provide additional information describing the malfunction or symptoms you are experiencing with your laundry center I may be able to provide more useful troubleshooting or an explanation.
Thanks,
Apr 03, 2014 | Frigidaire FGX831CS Top Load Stacked...
Does Frigidaire combo Washer/Dryer have any fuses inside cabinet ?
Hello - Generally speaking, Frigidaire laundry centers do not have fuse. The unit has a thermal limiter usually located in the dryer.
Oct 21, 2012 | Frigidaire FullFGX831C Size Stack Gas...
Roper REX3614KW Electric Dryer Logo
46 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
