Question about Turbo Ion Croc Turboion Classic Croc2 Titanium Regular 1-inch Flat Iron TurboIon Croc2 Titanium Regular 1" Flat Iron
Tring to figure out why croc classic turbo ion wont heat
When i turn on the iron, it shows that I want 450 degrees,and that the temp is 69 degrees it stays on for about 30 seconds and then err light comes on and then it shuts off.
What is the on/off temperature (heat) range for a RTH111 series
Heat range: 40 to 90 degrees F
Cool range: 50 to 99 degrees F
1 degree deadband
Here's the operation guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2603EF.pdf
Please mark my answer as helpful.
Jan 05, 2015 | Honeywell Digital Manual Heat/Cool...
How to take apart croc infrared flat iron 1.5
I can't tell you how to take it apart, but you might visit www..flatironrepairs.com and contact to see if it could be repaired.
Dec 15, 2012 | TurboIon Croc Infrared Flat Iron 1 1/2"""
Croc flat iron won't turn on
You might visit www.flatironrepairs.com and contact them to see if they could repair it. It's only $46.00 for the repair + s/h.
Dec 04, 2012 | Crocs Croc Infared Flat Iron 1"
How to Reset a Croc Infared Flat Iron 1
Mine does that too! And I don't know what to do!
Jun 07, 2012 | Crocs Croc Infared Flat Iron 1"
Says err and shuts off
Same thing happened to me, I just reset it and it works perfect again!
* to reset it: Plug your straightener in and hold the power button for about 20 seconds to reset it.
Nov 08, 2011 | Crocs Croc Classic Flat Iron Titanium...
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Croc only heats up to 230 degrees is there a way to reset it
CHANGE TEMPERATURE SETTING from CELSIUS to FAHRENHEIT
To Change the Temperature Setting from CELSIUS [230 Degrees] to FAHRENHEIT [450 Degrees]
If [230] appears on the display screen, then the temperature is set to Celsius. To change back to Fahrenheit:
1. Turn off your flat iron and unplug from electrical socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press & hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the digital screen. Your device is now in Fahrenheit mode.
Jul 23, 2011 | Crocs Croc 2 Flat Iron Titanium Plates 1"
My croc flat iron goes to 69 than shows error message
It's not working! I've tried unplugging it for a minute, plugging it back in and holding the power button on....am i missing something. I've had this damn thing for about 2 months. Please dont tell me i have to buy another one....AAAHHHHH!
May 28, 2011 | Crocs Croc Classic Flat Iron Titanium...
My croc iron will not heat up. It will not get any hotter than 69 degrees Fahrenheit.
Reset it and it will work fine! To reset it: plug it in and hold down the power button for about 20 seconds.
Feb 28, 2011 | Crocs Croc Classic Flat Iron Titanium...
2004 satur ion 2 wont start when below 20 degrees have to wait 30 minutes after trying to start then will start
It is a common problem on Saturn Ion... You have to replace the pass lock switch. The cost of the part is around $65.00 cdn. It is located behind the key switch.
Jul 29, 2008 | 2005 Saturn ION
Turbo Ion Croc Turboion Classic Croc2 Titanium Regular 1-inch Flat Iron TurboIon Croc2 Titanium Regular 1" Flat Iron Logo
91 people viewed this question
Top Turbo Ion Croc Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Turbo Ion Croc Health and Beauty Expert? Answer questions, earn points and help others
