Question about SanDisk Sansa e260 MP3 Player
Rotate Video 90 degrees
Want to rotate video clips 90 degrees to get maximum use of display screen
  • navykid Aug 14, 2007
    Really helped and worked; however, it didn't address the finish for someone not familiar with the program; Go to File and Save as AVI
Use VirtualDub... open your video, in the menu Video... Filters... click on Add, select the filter : rotate2, on the Rotation Angle, write : 270, you can test the angle with the preview button. You can alors enter : -90 instead of 270. Check the 'Expand frame to fit'. You can preview all the option, before converting the videos. Click ok...ok until you have the main windows.... Make sure you selected : Full Processing mode in the menu Video.
Posted on Aug 11, 2007
SOURCE:
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Acer tablet troubleshooting
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
How to rotate a video clip I took vertically??
If you have Windows Movie Maker, here's an easy to follow explanation that I used when I was trying to figure it out.
http://www.youtube.com/watch?v=HlqqlS8CDv4
Jul 28, 2008 | Pure Digital Flip Video Ultra Camcorder
I guess the site can help you.
http://www.labnol.org/software/tutorials/rotate-video-vertical-clips-90-degrees-virtualdub/2657/
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 20, 2008 | Canon PowerShot A530 Digital Camera
How to rotate movie in movie maker
Vista
Start - Programs - Windows Movie Maker
Click Import Media - select the video clip you want to rotate from your files and point and click on it to highlight it - then click the import button lower right corner of screen.
When the file name appears - drag the clip to the video line at the bottom of the screen - point at file name and hold down right mouse button while you move the mouse to point at the video timeline then let go of the right button to drop the video into the timeline.
Point and RIGHT click on the clip you just added to the timeline
Click Effects
Scroll down to Rotate 90 and click to highlight it (you could also flip the video with 180 or 270)
Click the ADD button
Then click OK
The video will rotate.
Be sure to publish and save the new video with a name you can find...
File - Publish Movie - to computer will save it as a file on your PC - to DVD will start another program to create a DVD...
Have Fun
Cheryl
Dec 22, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Display on the screen/monitor
im not sure if this will help but if your video card have its own control panel try going there and try looking for Rotate Display or something close to it. Im using Nvidia 6200LE and it has the option to rotate 90 and 180 degrees..you might want to try it
Nov 28, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
SanDisk Sansa e260 MP3 Player Logo
274 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
