My hp dv6000 suddenly stopped working and won't power up again. What is the problem?My hp dv6000 suddenly stopped working and won't power up again. What is the problem?
You can't post conmments that contain an email address.
http://www.insidemylaptop.com/hp-2000-laptop-disassembly/ Use steps 1, 2, and 8 - 15. Keyboard replacement is an easy job, just take your time and don't get frustrated when working through step 10. It can feel like you're about to break the KB but it is unlikely that you will.
a clean wipe of the partition and reset can be accomplished in the Bios functions, simply go into set up at boot and move through the menus until you achieve your goal. HP is well known for installing ghost partitions on their hard drives .
Is heatsink connected to this problem? (sic) Most probably not, it is more than likely a simple Driver problem. Try to startup in SAFE MODE, press F8 at boot time. If this works you could run a "System Restore" back to a time before it went faulty. Or troubleshoot from safe desktop.
hi, if nothing(even hp logo ) is not coming on the display then please try this. 1.remove the battery and then press the power button for 30 sec.Again refix it and check. 2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
dv 6000 are notorious for a bad video chip on the motherboard have four here all with the same problem the issue is a nonlead based solder the motherboard would have to be sent out to get reballed
if i'm reading this correctly, it sounds like it could be a motherboard/video issue. If that's the case then unfortunately you are probably going to need a new computer if it's out of warranty...
for now however, try shutting down the computer and removing all power (power cord, battery) for a few minutes, then plug it back in and try to boot.
same problem push power on lights flash goes back off.
