Question about Napoleon Fireplaces Napoleon Prestige PRO Series PRO600RSIB 73" Freestanding Gas Grill with 922 sq. in. Cooking Surface, 82,500 BTU, 4 Burners, Infrared Rotisserie Burner, 3/8" Stainless Steel Grids and Infrared Side-Burner
Glass turns black inside
Glass after short period of time turns black/ sooty
    Top Expert:
  • Napoleon Fir... Master
  • 35,531 Answers
You don't indicate where the glass is that becomes black/sooty but you can get cleaner specifically intended for cleaning glass fireplace doors. It is more effective than using ordinary glass cleaners
Posted on Apr 29, 2013
94 yz 250 fouling plugs bad
Could be fuel or oil fouling. Need to determine which first off. If it is black sooty fouling it is likely too rich also it too rich may be wet.
If oil fouling it is more likely to be much more material fouling and wet sticky material.
A wet, black and shiny deposit on plug base, electrodes and ceramic insulator tip indicates an oil fouled plug. The condition may be caused by one or more of the following: worn pistons, worn piston rings, worn valves, worn valve guides, worn valve seals, a weak battery or a faulty ignition system.
A dry, fluffy or sooty black deposit indicates an air/fuel mixture that is too rich, engine idling for excessive periods of time and/or enrichener usage for excessive periods of time.
A light brown, glassy deposit indicates an overheated plug. This condition may be accompanied by cracks in the insulator or by erosion of the electrodes and is caused by an air-fuel mixture that is too lean, a hot-running engine, valves not seating or improper ignition timing. The glassy deposit on the spark plug is a conductor when hot and may cause high-speed misfiring. A plug with eroded electrodes, heavy deposits or a cracked insulator must be replaced.
A plug with a white, yellow, tan or rusty brown powdery deposit indicates balanced combustion. Clean off spark plug deposits at regular intervals.
Sep 06, 2014 | Motorcycles
27 inch mac condensationon inside of screen
This problem is well known with imacs.
You can solve it if you have two suckers to take off the glass. You put them on the glass in diagonal and pull carefuly. Just have to wipe then.
Feb 11, 2012 | Apple Computers & Internet
I have 2007 suzuki intruder the front spark plug was replaced 3 times due to intermitant spark.Each time i check the spark plug no spark then replace the plug then spark then runs for short period the No 1...
Fouling of the spark plug makes the exhaust extremely hot due to the burning of the fuel mixture inside the exhaust pipe and the spark plug end turn to black, fouling of the spark plug may be due to too rich fuel mixture check the correct setting of the air valve.
Jul 10, 2011 | 2001 Suzuki VL 250 Intruder LC
Hi I have an old school (30yr approx) vulcan gas heater works brilliantly but the glass has gotten very sooty (blackened) can I dismantle to clean & how??
if the glass is sooty then cleaning it will not solve the problem , its not burning right causing the soot , needs to be serviced by a gas fitter.
Jun 30, 2011 | Vulcan AUW230A Heater
My fridge stinks while running And exhaut is sooting up real bad Any ideas ? Thanks Jon
<P>There are many reasons for smell. </P><P>But one sooty problem is the defrost heater may have burned out</P><P>Remove the inside back panel in the freezer and look for a black burnout</P><P>of the defrost heater.(around the bottom half of the coils. It looks like a stove bake element or its a glass heater</P><P>Replace the heater if it doesn't ohm out or if it is burned</P><P>&nbsp;</P><P>&nbsp;</P><P>If this was helpful please rate me.<BR>Leo Ponder Appliance-Tyler,Texas<BR><A href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</A> </P>
Aug 26, 2010 | Refrigerators
When driving my bike the engine stop. as i release trotle to pull over it backfires but after a few turn over it will start again it will do this 2 to 3 times per tank of gas also notice one plug is...
I am assuming the black color is a dry sooty black powder like condition, right? (If the black is oily and wet, it's rings, and will require a top end rebuild...) But, If it is the sooty black,Try this: Make sure the black plugs gap is the same as 1 of the other plugs. If not, correct it. Then do a spark plug swap with 1 of the plugs in the other cylinders. Run a few tanks of gas and pull both plugs. Did the good plug you put in the bad plugs place turn black? If YES, the problem is a rich fuel condition in that cylinder caused by dirty air filter, carb. problem, or a restricted exhaust.
Aug 18, 2009 | Honda GL 1200 Interstate Gold Wing...
Sooty background won't go away
You most likely need to get a maintenece kit on it what that includes is the fuser. It could be tht the fuser itself is damaged or has burnt toner on it causing it to apear dirty
Feb 12, 2009 | HP LaserJet 2605DTN Color Printer
Furnace filter is black and sooty wall seem to be sooty
   By sealed unit you mean that the burner air comes from outside of the house?      You have checked the heat exchanger for cracks by removing the burners and looking with a mirror and flashlight, correct, or had a service tech so?
The furnace burners have enough air and are burning clean (blue) with just a tip of orange at the end? You bought the house new and the fireplace has never been used?  If it has been used to clean smoke for the house for whatwever reason I woudl start by havign the ducts cleaned.   Another possibility I have seen is insolation inside of ductwork breaking down.
Jan 28, 2009 | RTO Home Heating Products 5.5HH240...
Condensation in view finder glass
Condensation usually occurs from the camera being taken from a dry, cool, place to a warm, humid place, or visa versa, in a short period of time (example: from a hotel room with A/C to the outside on a warm humid day).
Try putting the camera in a plastic bag when you know you're going to take it between two locations like that, as the air in the plastic bag will slowly adjust to the new temperature, reducing condensation
Dec 09, 2007 | Canon EOS-1D Mark II Digital Camera
Napoleon Fireplaces Napoleon Prestige PRO Series PRO600RSIB 73" Freestanding Gas Grill with 922 sq. in. Cooking Surface, 82,500 BTU, 4 Burners, Infrared Rotisserie Burner, 3/8" Stainless Steel Grids and Infrared Side-Burner Logo
102 people viewed this question
Top Napoleon Fireplaces Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Napoleon Fireplaces Grilling Expert? Answer questions, earn points and help others
