Question about Taylor 2008 C713-27 Soft Serve Ice Cream Yogurt Machine, 2 Flavor
What does L comp on to long mean I have a taylor c713
2 Suggested Answers
qasolution
  • 107 Answers
SOURCE: beater overload
if your mix level is low ice cream will freeze in cylinder which in turn will over amp the beater and cause it to trip. Check mix pump and make sure all orings are good.If mix isnt leaking out make sure it is pumping in.
Posted on Apr 19, 2012
WHAT IT MEANS R-HPR THERMAL FAIL FOR TAYLOR ICE CREAM MACHINE MODEL C713
That code means the right side hopper thermistor probe has failed. That is the sensor that reads the temperature of product in the mix hopper.
This is the part you need:
http://www.softserveparts.com/i-26471492-thermistor-probe-c712-c713-barrel-stanbye-probe.html
If you order it from us, I would be happy to put a technician on the phone to help you install it yourself.
Aug 01, 2017 | Taylor Ice Cream Makers
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
I just replaced the two beater drive motors on my Taylor c713 ice Cream machine now when I power up communication failure comes up
Every time I have seen that, it is just the USB cable on the mother board in the back of the machine.
1. Shut off and disconnect the machine from power
2. Remove the rear panel
3. Remove the electrical panel cover
4. Find the USB cable on the bottom of the board all the way to your right.
Mar 26, 2017 | Taylor Ice Cream Makers
My C713 water cooled yogurt machine keeps locking and only works when cleaned but only for a few hours then it locks again. Does anyone know why?
The temperature of the product is too high. If the product either in the cylinders or the hopper goes above safe temperature for too long the freezer will lock until the product is removed and the unit is properly cleaned. I would guess it's the hopper temperature because I think you would notice if the product that's dispensed is above 40 degrees. Soft Serve Parts C713
Aug 01, 2016 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Had a "comp on too long" message on the machine
this is normal if you just started the machine up from room temperature to freeze a batch, just reset it and it should not reappear , if you didn't and it's been running for days then your refrigerant is low or your cooling tubes are blocked with goo
Oct 20, 2015 | Taylor 2008 C713-27 Soft Serve Ice Cream...
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
Beater overload
Mar 24, 2012 | Taylor 632-33 Ice Cream Maker
Taylor 2008 C713-27 Soft Serve Ice Cream Yogurt Machine, 2 Flavor Logo
360 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
