Gateway zx6970 Problem booting up when new, sent back, now won't power up at all.
    Top Expert:
  • Computers & ... Master
  • 43,164 Answers
If the computer was returned to you with a repair warranty you should notify Gateway. You may have to return the computer again to have the repairs repaired.
Posted on Apr 29, 2013
4 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: My Gateway Essential 450 won't turn back on
This is where you can buy a new ATX power on switch,
http://www.axiontech.com/prdt.php?item=78201
The Power On switch is located inside the plastic Power On button assembly.
Age plus the heat developed inside the computer, have made the plastic of the Power On button assembly, brittle.
I suggest removing the Power On button assembly from the Front Panel.
(And disconnect the Power On switch cable from the motherboard.
BEFORE you do I suggest you make a drawing, and possibly some notes, as to where that cable's wires plug into the motherboard)
Computer unplugged from power, follow Anti-Static Precautions.
I would suggest using a hairdryer set to low heat, and moving the nozzle slowly back, and forth at the plastic until it slightly softens.
(Or you can use a bowl of VERY warm water. The switch is no good now anyway)
Is the problem something else?
It's either a bad Power On switch, or a bad Power Supply.
(Provided you are sure the surge protector is getting power, AND you have ensured that THE receptacle in the surge protector that the computer is plugged into, has power.
I have had a few surge protectors where just THAT receptacle was bad. Surge protector power LED light was on. Monitor, printer, and router had power. Just ONE receptacle was bad)
There is a simple test to perform to see which component is bad Power On switch, or Power Supply.
IF you do not know how, and wish to, please state in a Comment.
Regards,
joecoolvette
Posted on Jun 16, 2011
  • 139 Answers
SOURCE: Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Posted on Apr 06, 2012
SD Tech
  • 14553 Answers
SOURCE: Gateway GM5472 won't boot no power
No power and won't boot suggest a power supply problem in the tower--it is listed as a desktop unit.
What is common on a lot of units (computer towers, TV sets, you name it) is the stand by power supply which is on 7/24 fails.
The most common reason is filter caps dry out because cheap ones and ones rated too low a voltage are used.
The beauty of this is if the power supply is removed and opened you will be able to SEE the bad ones.
I will attach a photo of bad caps--tops which should be perfectly flat are puffed up from a little to a lot and or brown material is seen at top and bottom of the cap.
I have fixed many towers (desktop units) and other equipment with this problem---most of them at first had to be turned on a few times to get them to come on--it gradually gets worse until it will not make it on.
If bad caps are found you can usually buy a replacement supply at a reasonable price or replace the puffed up caps (seen as many as 8 bad in one computer tower).
This answer is based on the information you provided in your question and the answer from personal experience.
SD TECH
4_25_2012_5_11_26_pm.jpg the two larger ones are bad for sure.
Posted on Apr 25, 2012
Testimonial: "Thank you so much for the response. I thought the power supply but didn't know how to check it other then just replace it."
How do i connect my gateway zx6970 to tv
Hi
I don't know how helpful I can be but I will try.
Firstly. Are you selecting the correct HDMI input on the TV. I have four on mine, and need to select the correct one for what I want to view.
Secondly, have you got the HDMI outlet selected on the computer, via your graphics card controller, as I suspect that HDMI will not be the default outlet. I would expect automatic detection when connected, but that option may be disabled in the controller.
Cheers
Dec 26, 2014 | Gateway ZX6970 All-In-One Desktop...
Why would a gateway zx6970 all in one computer not power up??
have you checked the switch in the back ? have you tried another power cable ? is your outlet working ?
Aug 27, 2014 | Computers & Internet
Upload
What are you attempting to upload? Might you mean, 'download?'
Jul 15, 2013 | Gateway One ZX6970-UM10P All-in-One...
Dvd fell inside cpu of zx6970
go on you tube you should be able to find a tutorial video on how to dismantle it. just go slowly and document or photograph what you're doing.
Apr 11, 2013 | Gateway One ZX6970-UM10P All-in-One...
Touch screen not working
It should be still under warranty take it back to the place of purchase or contact them for support don't try to fix it you might lose any warranty
Dec 21, 2012 | Gateway ZX6970 All-In-One Desktop...
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
3 BEEPS -RAM
good either.
Apr 06, 2012 | Gateway GM5442 PC Desktop
Pc won't post or boot to bios when I press F2/F10 key Gateway DX4200-09
Hello, is it supposed to? on some machines you have to press DEL; others F8. Also, don't just press it once as you might be missing the point in the boot-up sequence where it 'looks' for some input from the kbd..... try and keep tapping the key as it's powering up. Regards, nicam49
Jul 08, 2011 | Gateway DX4200-09 PC Desktop
I have a gateway laptop that won't boot up. Only
try checking out to see if maybe you have a bad memory inside first. then if thats not the problem im gonna have to figure your hard drive might be going bad because of corrupt files and fragments.
May 27, 2011 | Gateway Laptop with Intel Centrino...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
