Question about Car Audio & Video
Kenwood kdc-x396 unit works fine but no display.
Kenwood kdc-x396 unit works fine but no display. Read about soddering resistors on the board. Will this work with this model and where do I sodder?
  • 125 Answers
SOURCE: Kenwood KDC-MP528
It is all described in the manual, page 27 Here is the instruction manual: http://inform2.kenwoodusa.com/manuals/KDCX589.pdf If you have problems downloading, send me an email where i can send the file.
Posted on May 25, 2007
SOURCE: KDC-MP532U display blank
Solution from Tech48:
The problem is not the faceplate for any of you, it is inside the main unit. If you know how to solder, you can fix is very easy. First take the top off the unit, there is 1 screw in the back middle. Then take the CD player out. It has 2 screws holding it in at the front corners at the bottom of the CD deck. Use a number 2 phillips and take out the gold screws holding the CD deck in place. Then you can pull out the CD deck, and be careful not to damage the ribbon cable connected from the CD deck to the main board. The deck can just sit up and over to the left to get it out of the way for what needs to be soldered.
Look inside the main unit on the board and you will see in the front right corner a series of surface mount resistors all connected in series. Just reflow that solder on them with a small amount of new solder added and the display will once again work perfectly. That solder is very heat stressed, that is the problem. I have fixed dozens of these over the last few years. Make sure you put it back together the same as it came apart, and you are done.
Posted on Jan 22, 2009
tech48
  • 624 Answers
SOURCE: Kenwood KDC-X590 Faceplate display problem
Yes, the problem is inside the main unit. I have fixed hundreds of these radios over the years.
The solder on these resistors get heat stressed and stop conducting properly. They just need a tiny little touch of solder.
With the radio in front of you and the face is facing you, take the top off and remove the CD mech. The CD mech can just be set over to the left a little and the ribbon cable to it can stay connected. Just move it out of the way gently. You will see a series of resistors in the right front corner area of the main board on top. They have 2R7 printed on them and there are quiite a few, all in that main area. Just resolder them and put it all back together again and the display will work normal.
Dave
  • 773 Answers
SOURCE: I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Posted on Dec 15, 2009
  • 35 Answers
SOURCE: I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Posted on Jul 28, 2010
AM Bandwidth
What kind of car?
Feb 07, 2014 | Kenwood Excelon KDC-X396
Unit works, no display. where do i resodder on motherboard?
Check the connecting cable. If the unit is on warranty please contact the service centre.
May 02, 2013 | Kenwood KDC-X396 Pandora Internet Radio CD...
My faceplate does not show display on my Kenwood kdc-mp632u. The lights work and the head unit in general plays the radio and cd's ect. now I have read somewhere that there are resistors inside so that...
I had the same problem and I resoldered the resistors on the board inside the stereo and it worked. Unscrew and remove the top cover and the CD slot. There are 10 of them located on the lower right side of the board. Good luck.
Jun 12, 2010 | Kenwood KDC-MP632U
Kenwood KDC-MP428 - the display is out but works otherwise
there are several surface mount resistors on the right side inside of the deck that need to be resoldered.
Jan 07, 2010 | Kenwood KDC-X590 CD Player
I have a Kenwood KDC MP532U. The face plate will not display.
it more than likely has bad solder connections inside the radio on some surface mount resistors usually located on the right front of the radio as it faces you.
Sep 16, 2009 | Car Audio & Video
Dave
Jan 20, 2009 | Kenwood KDC-X590 CD Player
Display on Kenwood Out
I am not sure exactly what solution you are reffering to, but the KDC-MP532U has a problem with the display going out that is the result of heat stressed solder on the main board. The surface mount resistors that are located on the right side near the front of the unit, as you look into it with the display facing you, are the culprits. This is common in about 3 or 4 Kenwood models. These surface mount resistors are on the top of the board, so the board doesn't need to be taken out to fix it. Just the CD mech does. The surface mount resistors just need the solder reflowed, an easy enough job if you know how to solder. They are all lined up connected to each other, I don't remember the reference numbers, but if you can recognize what a surface mount resistor looks like, you should be able to find them very easy.
Thanks for the compliment on the other post, it is appreciated. A good rating would also be appreciated.
Thanks and good luck,
Dave
Jun 30, 2008 | Kenwood KDC-X590 CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
Car Audio & Video Logo
155 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
