Question about Kitchen Ranges
Oven problem both heating elements work, but oven will not heat past about 375. the broiler does not heat to much more than barely hot. there are no error codes and everything else works fine.there is a low volume high pitched whine heard best at the front of the downdraft.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on May 03, 2013
NephetZ
  • 9 Answers
SOURCE: Oven heats very slowly (Jenn-Air JGS9900BDS).
hi, Could be a bad bake element or a bad temperature sensor. If the element will glow bright red/orange with no hotspots it is OK. Take a volt/ohm meter set for ohms and check the temp sensor. If less than 1050 ohms replace it.
NephetZ
Posted on Jul 08, 2009
fridgetech
  • 473 Answers
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 05, 2007
SOURCE: Oven will not heat up
same problem here. Looking for solution..
Posted on Jul 04, 2008
  • 63 Answers
SOURCE: The heating element on the bottom of the oven does not work.
lots of those old elements are still out there...some come out with simple pull...or two screws holding the wires!.. take to appliance store (sometimes even lowes!)
Posted on Mar 16, 2009
  • 530 Answers
SOURCE: oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
Posted on May 28, 2009
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Broiler element won't heat. oven won't hold
check the broiler element for "Hot-Spots" where its dis-colored and is ready to break
Oct 07, 2009 | Whirlpool RS696 Electric Kitchen Range
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Mer5755qab oven takes an hour to heat to 200
Either your bake element is bad or there is a bad connection going to the element. This is a very high current connection so bad connections are always a possiblity. Also check and make sure your broil element is working as some ovens use it for pre-heat. Do both elements seem about the same temp? You can turn the oven on and carefully hold your hand a few inches from the element to see if they are getting equally hot. If your connections are good to the elements then one of the "calrod" elements is probably bad. You can also check the resistance of each element. Not sure of exact reading but a higher resistance means less current going to the element. Just compare reading on each one and go from there. Good luck!
Mar 13, 2009 | Maytag MER5775Q Electric Kitchen Range
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Sep 07, 2006 | KitchenAid KERC507 Electric Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
