Question about Sony KDF-50E2000 50" HDTV
Replace lamp I replaced the lamp(it wasnt completely dead yet) and the 3 red blinking lights come on. When I put in the old lamp the tv works. Why wont this new bulb work? The door is positioned correctly.
    Top Expert:
  • Sony Master
  • 75,178 Answers
Check the site linked below. It has details about lamp replacement and other adjustments to many brand TVs, including Sony PTVs. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
Posted on Apr 30, 2013
welcomejee
  • 10594 Answers
SOURCE: XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
Posted on May 30, 2009
  • 5 Answers
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Posted on Sep 09, 2009
beachbum069
SOURCE: I have a sony kdf-50e2000 i replace the lamp last
there is a micro switch on the bottom right where the blub plugs in, you need to gently pull it back out...WITH THE SET UNPLUGED
Posted on Nov 25, 2009
  • 1039 Answers
SOURCE: Sony Grand Wega KDF-50E2000 3 red blinks
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
Posted on Apr 01, 2010
  • 1619 Answers
SOURCE: sony tv model kdf 50e2000 shuts off and red light blinks 3 times.
You need to open up set and clean out all fans of dust or the new bulb isnt being cooled, or the color lcd isnt being cooled shutting TV off.
Posted on Apr 17, 2010
What is the solution to the blinking green light and welcome screen then tv shuts itself off
I recently had this problem on my model as well, though it was lessthan a year old. The method that worked for me is to update thefirmware of the TV itself; you can download the new software, with complete instructions on how to update your TV at http://support.mitsubishi-tv.com/documents/WD-60C9
After doing this, my set started working again.
Do not replace your lamp. the light will blink red for a bad lamp, not green.
Jun 18, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
I have a Sony KDF-E55A20. I just replaced the bulb, the old bulb was broken. I replaced the bulb but the TV still does not work. There's a series of 3 blinking red light. What does this mean? After I put...
Put lamp cover back on tv as it will push a safety switch inside then tv will turn On.
Lamp cover is first thing that you removed to replace lamp in tv.
Hope this will help you.
Thanks.
Nov 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
When i press power button green light comes on and then red light blinks 2 but the tv does not turn on
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
Aug 26, 2010 | Mitsubishi WD65737 65" DLP TV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
TV not working after replacing lamp
yes, the door has to engage a switch and if it doesn't the tv will not come on it usually has a 3 blink error if this is the problem. Is your red light flashing in a 3 blink series?
Sep 16, 2009 | Sony KDS-R50XBR1 50" HDTV
Red light blinking 3 times on Sony xl2400 lamp replacement
I solved this problem myself. You have to continue working with the housing until the connections meet just perfect. It was extremely frustrating but in the end I got it to work.
Aug 28, 2009 | Sony (XL-2400) Projector Lamp for...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Panasonic PT-53WX42 - When I turn the TV on, the red light comes on but, no sound or picture.
Does the light blink? If it is blinking a 3 code, the IC's need to be replaced. Those three lamps as you called them are not lamps, they are the three picture tubes.
Jan 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Sony KDF-50E2000 50" HDTV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
