I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no longer effective.
    Sergeant:
  • 316 Answers
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Posted on Apr 29, 2013
    Coninuosly repeats spin cycle, any suggestions how to remedy this? I have to manually cancel the cycle in order for the machine to stop recycling through spin
    I had a Centennial washer on a service call doing this just the other day... After putting it trough diagnostics I found no errors and all the washer's mechanics tested okay. After resetting the control by putting it trough the diagnostics mode it continued to repeat cycles without restarting the washer.
    • Try running it through diagnostics and see what error codes are in the memory. (Guide is linked below)
    • What are the codes? do they give any more clues?
    • clear the codes and run a test cycle.
    • does it work?
    • if it checks out properly with the diagnostics it's probably a bad control board...
    Maytag Centennial Washer Diagnostic Guide
    If it does turn out to be the control try contacting Maytag (Whirlpool) for a parts concession... Whirlpool customer service guide is linked below.
    Hope that helps! Good luck!
    Jun 16, 2015 | Maytag Centennial Top Load Washer
    Fault code f26
    This error code indicates that the door needs to be opened and closed.
    The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
    The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
    If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
    If Pause/Off or Pause/Cancel does not work:
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    3. Re-select the cycle and press Start.
    Jul 30, 2011 | Maytag Washing Machines
    Code 28
    Error code F28 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below. In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
    • Unplug or turn the circuit breaker off for 30 seconds.
    • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
    • Press the Pause/Cancel/Stop button twice to clear the display.
    • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
    Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    As it started through the rinse cycle, it stopped and flashed error codes (H and F I believe). The door locked button is lit and I've tried all the normal suggested ways to get the door unlocked, to no...
    f h means no water check your cold water line make sure the strainer is clean .will be at the back of washer where hose connect. to clear this hit pause/cancel twice
    Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Duet Steam washer, F20 error. help
    make sure pump is clear. open toe panel and access pump.
    Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Error code f22 whirlpool duet wash cycle
    f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
    If you're getting an F22 error, you will want to check anything to do with the door latch switch.
    Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Unable to cancel cycle and restart machine
    Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
    Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
    F4 error code onmodel gsx9885jq0 whirlpool washer
    Hello, Let's see if I can help.Try this first.
    1.
    Press Pause/Cancel twice.
    2. Open and close the washer lid.
    3. Reset the cycle and press Start.
    If the problem persists, press Pause/Cancel twice to clear the
    display. Call for service.
    Dec 31, 2008 | Washing Machines
    Kenmore Elite He3t front load washer - error code reads H & F
    the F code is a puwer outige. This is how to fix
    Select PAUSE/CANCEL twice to cancel the cycle. Select
    DRAIN & SPIN if there is excessive water in the washer.
    Re-select cycle and press START. If the problem remains, call
    for service.
    This is what an HF code is.
    "FH" (Water Inlet Problem--no water or insufficient water
    supply)
    Select PAUSE/CANCEL twice to cancel the cycle. Unplug
    washer or disconnect power.
    Check the following:
    Are water faucets completely turned on?
    Are screens at inlet hose connection to washer clogged?
    Are water inlet hoses kinked?
    Are water inlet hoses frozen?
    Plug in washer or reconnect power. Re-select cycle and press
    START. If the problem remains, call for service.
    Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore 22082
    OL on my washing machine
    May 17, 2008 | Kenmore 22062 Top Load Washer
    Washing Machines Logo
    154 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
