Sharp data wizard
There's a communication error happening when transmitting changes from my SDW back office computer to the main register in our cafe.
2 Suggested Answers
flexion1
  • 737 Answers
SOURCE: receiving this message when trying to communicate
If you are using PClink, it is not Vista compatible as far as I know. Try it on an XP machine.
--------------------------------------------------------------- If anyone is looking for a Sharp XE-A401 manual, there is one here
http://the-checkout-tech.com/manuals/cashregisters/Sharp9.php ---------------------------------------------------------------
Posted on Feb 09, 2010
How to correct error code 4 in 10 on Sharp pocket computer pc-1270
I found the answer for the PC1500, and I'm guessing the error codes for the PC1270 will be similar. Here is what the manual says:
This error occurs when there is no DATA corresponding to a READ command, for example:
10 READ X, Y
20 DATA 10
30 END
The display will say, "ERROR 4 IN 10"
The solution is to provide enough DATA to satisfy the READ. For example, change line 20 to read as follows:
20 DATA 10,15
Hope this helps.
May 04, 2017 | Sharp Office Equipment & Supplies
How repar this problem u2 - 23 sharp arm - 451 u
SRAM memory individual data check
sum error (ICU)
Check sum error for every data in the
SRAM memory of the MFPC section
(Communication management table,
sender registration data, etcSRAM trouble
Control circuit runaway due to noises
ICU PWB SRAM access circuit trouble
.)Automatically initialize the data related
to the check sum error by turning OFF/
ON the power.
Since the registered data are deleted,
register the data again.
Use SIM16 to cancel U2 trouble.
Replace the ICU PWB.
Mar 12, 2015 | Sharp Office Equipment & Supplies
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Computer Event Register
Search for 'event log' or 'event viewer' in Windows 7, xp, vista
I don't know about Windows 8 or Apple Safari
Generally the event log registers each event... and if enough certain error types accumulate within time frame parameter, the computer issues error message.. or contacts the server at Microsoft possibly signaling need for update etc.
May 28, 2013 | Computers & Internet
Sharpdesk issues
I had this same issue. The problem was because the client was using an older version of Sharp Desk on Windows 7 machines. After uninstalling SD, I installed SD 3.3. No more issues.
Jan 23, 2012 | Sharp Office Equipment & Supplies
I have installed Avery for my Word 2007. I am trying to do labels from an existing excel spreadsheet, also 2007, and when I get to the point to select from existing file it says there was an errora and...
Jill (guerinje),
I might have a solution for you.
I recently ran into this issue as well. When using the Avery Wizard (Avery Wizard 4.01 - US 20111209.exe), I was able to select the Avery Product template, the customization Design, and could select the 'Merge data from an existing data file' option, but when I clicked 'Next' to continue, I got an aborted list of recently used data files and then an error pop-up stating that the Avery Wizard encountered an error and needed to close. There was also the option of notifying Microsoft of the error.
Here is the solution that worked for me - TAKE CARE - This solution makes changes to the computer's Registry: WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall Windows.
These instruction are for Windows XP. Other operating systems will most likely require adjustments to the steps below.
Step 1: Open the Registry Editor: Click the Start Button -- Select 'Run...' -- Type regedit -- Click 'OK'
Step 2: Select the Registry Entry: In the Left-Hand pane of the Registry Editor, double click on 'HKEY_CURRENT_USER', then on 'SOFTWARE', then 'Avery', then 'Avery Assistant', then '4.0', then single click on 'Recent Data Files'.
Step 3: Backup the Registry Entry: On the 'File' menu, select 'Export...' -- Select your Desktop for the 'Save in:' field -- Enter a name for the backup of this registry entry: I used 'Avery Recent Data Files' -- Make sure the 'Save as type:' is Registration Files (*.reg) -- click the 'Save' button.
Step 4: Delete the Registry Entry: In the Right-Hand pane of the Registry Editor, ignore the entry for '(Default)', select the entry for File1, hold down the 'Shift' key on your keyboard and then select the last file value (for me it was File9 - File10 was actually listed between File1 and File2) -- When all the File entries are selected, right click on them and select 'Delete'.
Step 5: Exit the Registry Editor: Either Select the File menu's Exit option or click the red 'X' button in the upper right corner of the Registry Editor Window.
Step 6: Restart the computer
Step 7: Login again
Step 8: Test the Avery Wizard in Word to verify it works. If it does not work: You should restore the registry values you deleted by double clicking on the 'Avery Recent Data Files.reg' backup that you saved to the desktop in Step 3.
Step 9: If the Avery Wizard works again: You can delete the 'Avery Recent Data Files.reg' backup that you saved to the desktop in Step 3.
And that's it. This process worked on the two computers that were having this issue at my office. Hopefully it will work for you as well.
Good Luck,
fnis
Apr 14, 2011 | Avery Wizard for PC
Sharp wizard. Batteries dead. can you retrieve information???
Depends. The Wizards had backup battery. As long as it is still good, then your data is safe. if you saved / copied / made backups to the compact flash card (Type 1 option) as well, then you have a copy there that you might be able to use in a computer. Sharp used a different, not quite proprietary, format for storing data though. You may be able to see the data on the computer, but won't be able to open the individual files.
If your backup battery is dead, and the main batteries are dead, and you don't have backups on CF, then your data is likely gone.
Jun 23, 2010 | Sharp Zaurus ZR-5800
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Aug 22, 2008 | Sharp AR-M207 All-In-One Laser Printer
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
