Question about HP LaserJet M1522n MultiFunction Printer
[HP LJ M1522n] Formater board (CC368-60001) in HP LJ M1522n (orgin. CC396-60001)
My formater board (CC368-60001) broke down. I could not find such a use, so I bought from M1522nf (CC386-60001) with fax module. But I read on a forum that will not work. Is this true? : ( If so, what does it take to work?
POCBM
  • 121 Answers
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Posted on Mar 25, 2009
SOURCE: Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Posted on Jun 02, 2009
SOURCE: HP M1522NF: KEEP RECEIVING A LOW MEMORY MESSAGE
KEEP RECEIVING A LOW MEMORY MESSAGE WITH AN INCOMING FAX??
Posted on Jun 03, 2010
  • 223 Answers
SOURCE: Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Posted on Jul 15, 2010
printerman40
  • 170 Answers
SOURCE: My M2727nf is not not initilizing and is out of warranty
1. Remove the left cover.
2. Disconnect five connectors (callout 1; GND wire lug, J36, J2, J32, J34) and five FFCs (callout 2;
J4, J27, J28, J31, J26).
Remove the formatter (1 of 5)1
132 Chapter 5 Removal and replacement ENWW
3. Remove six screws (callout 3), and then separate the formatter from the product.
Remove the formatter (2 of 5)
CAUTION: Make sure that you install the protective sheet behind the formatter when you reinstall
it. Failure to install the protective sheet might cause a short circuit and damage the formatter.
4. For products that use an Asian character control panel only
: use a pair of needle nose pliers
to release the Asian-character control-panel-display PCA spacer from the formatter.
5. For products that use an Asian character control panel only: remove the Asian-character
control-panel-display PCA from the formatter. Install the PCA on the replacement formatter
(connector H3).
Here's where you can get your formatter... Click Here!!
Hope this heps and if so Please mark this a FixYa!!
Posted on Jul 19, 2010
Testimonial: "Thanks for your help!!"
Hwo do i repair error 52 in hp leserjet pro 400 m 410 dn
52 error is scanner related not formatter. HP has had issues with some serial number ranges of this printer having bad scanners which they will replace. You should contact HP regarding this problem.
Sep 09, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M1522
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
Contact Hewlett Packard for possible Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
49 err 6400444 tune off then on
there is problem with formater board first try to update firmware may be solve yours problem if not just change formater bord and enjoy
Jul 15, 2014 | HP P2055DN LaserJet Monochrome Printer
Hp laserjet 3005 exchange the formater board then the board is 3005d.the printer is not duplax
Depending on which P3005 model you have I don't suspect there should be a problem. You just won't be able to duplex of course and of course you will have empty connections where the duplex connections would go.
I have interchanged usb formatter only boards with network boards on other HP models and vice-versa.
Nov 05, 2011 | HP LaserJet P3005 Printer
HP Colour Laserjet 5550dn. Once switched on it goes through memory check; display lights and hp logo on display screen. Then displays on screen "Initializing . . ." Doesn't go any farther - just...
i hope that the problem is not in some of your printer boards, but i have to tell you that you have to expect problems with POWER SUPPLY BOARD or FORMATER BOARD. Please call service for help
pifonski
Apr 19, 2011 | HP LaserJet 5550 Printer
Printer continues to require restart to get it to print
I can't say for sure but that printer has a weak formater board. It always goes out and cost about 130.00 or so. Its easy to change. Steven 818-888-0006
Mar 10, 2010 | HP LaserJet P3005n Printer
Scanner error 5 on my hp laserjet M1522n MFP
This is due to a formatter failure. The scanner assembly has been damaged and will need to be replaced as well as the formatter board.
Try an nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Oct 02, 2009 | HP LaserJet M1522n MultiFunction Printer
Counter reset
only way is to replace the printer....or the mother board...take your pick
Apr 17, 2009 | HP LaserJet M1522n MultiFunction Printer
HP LaserJet M1522n MultiFunction Printer Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
