Question about Sharp Televison & Video
Half of the picture is showing a bad frequency
    Top Expert:
  • Sharp Master
  • 75,424 Answers
Check the site linked below. It has screen shots to some faults. Check it and determine. The details you provided here is not sufficient to post a solution.If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
MY TV IT SHOW HALF SCREEN I HAVE CHANGE IC STR BUT STILL THE SAME WHAT SHOULD I DO
Repair the fault.
Half a screen is normally caused by a faulty boot strap capacitor or low frequency coupling capacitor.
Dec 07, 2017 | Televison & Video
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
Tv screen only shows half of the picture ?
I would imagine the bottom or top half is black. My first suspicion, the vertical IC has bad grounds and needs resoldering. Do not short the pins together with excess solder! I would certainly start there for repairs. Thanks for asking and show all hands of support!
Aug 13, 2011 | Hitachi 57F500 57" Rear Projection...
Half screen showing picture other half showing color lines
This is a catastrophic and known failure of older Toshiba sets, not much you can do, try to take out a retrospective extended warranty, wait a month and claim, good luck.
Apr 19, 2010 | Toshiba REGZA 52RV530U LCD TV
The television once on has good picture then black rectangular blocks the bottom half of the screen showing only half the picture, very annoying. how can i fix this myself?
look for the vertical section of the printed circuit board.there is a vertical driver ic and it is maybe bad...... either the soldering,or the ic.
if you bang on the tv and the picture regains deflection,there is a bad solder joint or connection.
there are a few capacitors too 100mf 25 volt 4.7 50v also 22mf at 50v
Jul 17, 2009 | Aiwa Televison & Video
Only bottom half of the screen shows, also i need the service menu. How can i get to it. Thanks in advance!
I'm not familiar with this model of Sony, but the picture shows a CRT TV. If this is so, your vertical deflection circuit has gone bad (it's nothing to do with the service menu). This can be caused by bad capacitors in the vertical deflection circuit, a bac IC, bad power supply to the IC, bad solder connections, or a combination of any of the above. In this case I would use a scope to test the circuit to see where to start from. You can always do a visual inspection to check for blown or burnt parts and bad solder connections. Other wise you'll have to have a sevice person look at it.
May 28, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Old tv only shows half picture
it looks like some caps are bad in the set.
Have it serviced by a TV repair shop
Aug 02, 2008 | Televison & Video
Sony Trinitron Top Half picture blacked out
You could have a bad capacitor 35v 100uf ,1uf 50v ,VERTICAL ICs have 7-11pins depends on which one you need LA7830-or 7833,7835,7836,7837 7838 make sure you get correct part.
ThankYou for using FixYa. Have a Nice Day
Feb 07, 2008 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
