Question about Black & Decker D6000 Iron
When ironing just quit. wont turn back on. - Black & Decker D6000 Iron
Why do my straighteners keep turning off
I had the same problem. The solution was quite simple actually. I took the iron apart. The problem was that one wire got loose. I soldered it back where it belongs and now the iron works again.
CAUTION! This procedure should be done by a qualified electrician only!
Jul 14, 2014 | Remington S9500 Pearl Hair Straightener
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
My Rowenta DG8030 steam iron leaks and sputters all over the clothes. How do I clean it. I can't find the manual...
treat it like a coffee maker mix some white vinegar and water then run that solution through the tank. hold it over a sink of course then rinse out with clean tap water. In the future use distilled water and you wont have that problem again for quite some time.
Apr 01, 2011 | Rowenta DG8030 Iron
Shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Jun 20, 2010 | Euro-Pro Shark GI490 Iron
Iron cuts off in the middle of ironing
It is probably an intermittent cord connection next to the strain relief. You can simply remove the back cover, cut the cord, pull the remaining cord (approx 6-8") and reconnect it. You can also order part # RS-DE 245954 the whole cord assembly including the circuit board for about $25.
Apr 17, 2010 | Rowenta Irons
Iron wont turn on
Probably a broken or burnt wire, you need to open the iron and tie or solder the wires back together, it'll be functional again. Good luck
Feb 11, 2010 | Maytag MLI7500A Iron
Panasonic NIA56NR NI-A56NR Iron shut off and wont turn back on
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 04, 2009 | Panasonic NIA56NR NI-A56NR Iron
Wont turn on
I agree.
It is probably a loose screw (if you shake the iron, you may hear it rattle).. The iron is most likely good, just needs a 5 minute repair.
If you want to do it, or find someone to do it:
1. UNPLUG the iron.
2. remove the 4 screws from the back end of the iron.
3. Open the back plastic plate.
4. There will be a wire with a loose screw; tighten it.
5. There may be a broken wire near the screw; if so, remove the eyelet that is on the screw. put the screw back on and wrap the broken wire end onto the screw and tighten.
6. Replace the back plate.
7. Plug back in and use for a few more years.
Hope this helps!
Sep 04, 2009 | Rowenta Power Duo Iron
Broun iron (model SI6285) quit working
Small appliances nowadays aren't really designed to be taken apart. Most likely there wont be replacement parts, you are probably better off just buying a new one.
Jun 06, 2009 | Braun SI6285 Iron
Problem with Philips Azur Precise 4340 Iron
i had the same problem and the Philips hekp site was no use. I turned my iron off until it was completely cooled down then switched it back on again, with the steam number turned to 5 and the heat on max. as soon as the ready light went off, i put my iron in the horizontal position and shook it back and forth (quite vigorously) and it seemed to have dont the trick!
Jul 09, 2008 | Irons
Black & Decker D6000 Iron Logo
32 people viewed this question
Top Black & Decker Irons Experts
tfelton3
nmccully
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
