Question about Franklin Electic Franklin Electric Industrial Motor 3/4 Phase 1
1101451105 motor spec
Torque specs of moter mounts of 350 chevy
63 lbs-ft. biggest thing to make sure of is that they are tight. You really don't need to torque to a specific torque. But the specs are here for your needs.
Nov 10, 2016 | Chevrolet Cars & Trucks
What is the compression specs for this motor
compression specs for all motors are the same for each motor regardless of application
petrol motors would be 145-150psi
Sep 07, 2015 | Boating
What is the torc specs for a 2005 ford f650 Cummings motor
try auto zone library if your looking for specs for the whole motor buy a manual for 20.00 its a great deal
May 06, 2015 | Ford Cars & Trucks
Blower motor
They do not publish "specs" only a part number.
Jun 29, 2013 | 2008 Nissan Rogue
How to find 2000 Chrysler jxi convertible top motor
sebring transmission pan torque spec need torque specs for 2000 Sebring jxi convertible, transmission pan torque specs and bolt tighting
Nov 29, 2011 | Cars & Trucks
What will make you change top end
A compression test is the accurate way to assess the condition of your top end. Although the spec's will vary from motor to motor, anything below 120 psi usually indicates it's time to rebuild it. Some motors that's as high as 150 psi, so do some research and find the service limit spec for your bike. Good luck!
Jun 13, 2011 | Honda HT1508 Motorcycles
Torque spec for 2002 venture van with 3400 motor
haynes catalog has them in front of each section
Dec 27, 2009 | 2002 Chevrolet Venture Passanger
Need original blower motor and cap. specs for Ruud Deluxe 90+
The motor specs can change from time to time depending on what the manufacturer has in mind.
If it has locked up check first and make sure the squirrel cage fan has not moved and is binding on the housing.
If it is clear to turn and wont turn,, the bearings must be bad, and this is probably NOT a problem with the motor being "wrong". Its just the way things are made.
Contact a RUUD distributor for the specs you request.
Jul 10, 2009 | Ruud UBHC Air Conditioner
Furnace Blower Motor Specs
That information is usually on the data plate on the furnace and on the motor itself. All you need to know now is the HP. Other than that a universal consolidator motor is an easy fix too. It can handle 1/6-1/3HP.
Dec 17, 2007 | Heating & Cooling
Franklin Electic Franklin Electric Industrial Motor 3/4 Phase 1 Logo
85 people viewed this question
Top Franklin Electic Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Franklin Electic Tool and Hardware - Other Expert? Answer questions, earn points and help others
