Riso rn 2030 ui
How to reset the error code T98-540? can any one knows to fix it?
SOURCE: Somebody that speak Spanish? Riso RZ
i have problems with Riso RZ 230 EP
1\ A-01-211
2\ P-19-217
3\ d-17-237
number three last problem
pls help me quckly
Posted on May 27, 2012
  • 55 Answers
SOURCE: riso rz220 ui error code
Error P02-405 means: The upper-limit sensor does not go ON within 12 seconds after the elevator motor operates in the raising direction.
Posted on Apr 29, 2011
  • 55 Answers
SOURCE: HOW CAN I SOLVE THE ERORR CODE T04-513 IN MY RN
Error T04-513 means: The overflow sensor is ON for a set number of times in succession.
Check the ink in the drum and the sensor which is a thin wire. If there is to much ink remove some. If the sensor is bend then correct it.
joseph_ylles
SOURCE: Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Posted on Jul 26, 2012
fivemayur
  • 414 Answers
SOURCE: riso rn 2030ui error code A01-211
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
Posted on Feb 26, 2013
Rn 2030 ui error code t-98-540
t98-540 Cannot read/write data to EEPROM in the print drum. hope to be of help.. EEPROM problem is eminent.
Oct 21, 2013 | Riso RZ220 Duplicator
Riso rn 2011 error code TO1 520
If you tried to reset and it failed, call for service technician
Jun 18, 2013 | Office Equipment & Supplies
Riso rn 2030ui error code A01-211
Feb 25, 2013 | Riso Office Equipment & Supplies
I need to repair my riso RN 2100 ep
my riso rn2100 ep have b01-730 error ?
pleas help me .....
Aug 10, 2012 | Office Equipment & Supplies
Error code T01-521 on RISO RN 2130
I have an RP3105 with this error code. Next to the magnetic clamp that holds the master in place is another lever mechanism that lifts the master to present it to the waste master mechanism. This has a small white plastic wheel which is engaged to make it move. On my machine the wheel had broken in half. I superglued the two pieces together and everything works perfectly
Feb 04, 2011 | Office Equipment & Supplies
Riso rz220 ui error code P02-405
Jan 20, 2011 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
Oct 22, 2008 | Office Equipment & Supplies
Risograph rp 3100 ui
Reset machine... and check connectors to the boards... its a communications error to the digitizer cpu
Oct 13, 2008 | Riso RZ220 Duplicator
85 people viewed this question
jasbo
jasbo
