It would helpful if we knew the Make , Model of Laptop and the OS you are using.
Yes, that's it, there is also a little more to it then that, if you haven't got it yet, message me.
[email protected]
SOURCE: ACTIVATE Wireless Link????
On some models check to make
sure that the actual physical "switch" is turned on (if there is one). Usually located in
the front or side of the laptop. Also, make sure your HOLDING the function key while pressing F2, otherwise it won't work. Hope this helps!
SOURCE: hello, my laptop cannot connect using wireless
Hi, if you are using windows XP, check for your control panel, look for network connections, and then on the LAN or Highspeed internet portion, check if there is an icon for wireless connection, if there's none, the driver of you wireless is not installed. If there is, right click the icon and then select enable.
SOURCE: I am unable to activate wireless card. I have to
It could be a drivers problem... Unistall the drivers from the device manager and install a fresh one from the dell website.. Try pressing the FN+F2.. Still no go.. Try to check whether the keyboard is working.. Still no go - resaet the Wireless card... Still no go.. Replace the wireless card..
