Home | Tricity Bendix | AW1000W Front Load Washer | Machine not draining
Tricity Bendix AW1000W Front Load Washer
Problem for Tricity Bendix AW1000W Front Load Washer
By mahonyaoife on Mar 14, 2009
I turned on machine but it did not drain at end of cycle. Now no cycles work. It just hums on all settings but nothing happens.
Solution #1
posted on Mar 14, 2009
Not Rated)
jonniewalker
Rank: Guru
Rating: 88%, 568 votes
the washing machine uses an electric pump. Unlike the older machines pumps that used to be driven by a belt, Then newer washers pumps are driven with an electric motor.The first thing you need to do is to disconnect the washer from the wall outlet
Next you need to remove the front panel from the washer. To do that you will need to be use a spatula. You need to place the spatula between the front and top panels to compress the two front panel holding clips.
After removing the front panel you need to connect the washer to the wall outlet.
Set the timer on the spin cycle and pull the knob to turn the washer on. Listen to see if you could hear the motor on the pump turning or humming. since the motor hums, that is an indication that something is preventing the pump motor from starting.
Disconnect the washer from the wall outlet, empty the water from the machine (make sure you have plenty of towels to clean any water spills) this connect the hoses from the pump and check the pump for any obstructions.
If the motor on the pump is not running at all, then you'll have to check the pump motor for continuity. If the pump motor checks OK for continuity then you need to check the two wires that connect to the pump to make sure that the timer is sending 120 volts to the pump.
In conclusion, is not that hard to find out why your front load washer is not draining. You either have an obstruction, a bad pump or a bad timer.
To check the motor in the electric pump you will need to get the multitester. analog multitester. Make sure you read the instructions on how to use you multitester to read resistance and voltage
Comments:
Mar 14, 2009
- hope this helps if you need further help pls do let me know i will appreciate a fixya rating
Mar 14, 2009
- humming noise, check for an obstruction inside of the pump that is preventing the pump impeller from turning. Also the pump bearings could be worn out and and instead of the motor turning, it could be frozen in place.
r is disconnected from the wall outlet before proceeding. Disconnect the pump wires and take a reading with your ohms meter, the reading should be between 5 and 10 ohms.
If the needle in your meter doesn't move, meaning that the reading is infinity, the pump is bad and must be replace. That could be the reason that your is not draining.
Was this helpful?
Yes
No
Popular Solutions for Tricity Bendix AW1000W Front
Questions and Unsolved Problems for Tricity Bendix AW1000W Front
Do you recommend Tricity Bendix AW1000W Front Load Washer?
Answer
Answer
I accidentally pulled out the drain hose, washing machine is now leaking, what do I do?
Answer
My 8 place Bendix dishwasher does not fill with water. It seems to go through the motions of washing... (More)
Answer
the faric softener isnt going into the washing mashine
Answer
i have a new drive belt for my tricity bendix autowasher 1000, but it seems far to tight to fit on,... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tricity Bendix AW1000W Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14193
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
