Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Tail light Break light and running light not working. New bulb fitted, what could be the problem
    Sergeant:
  • 319 Answers
Check your fuses to see if the one associated with these lights is blown.
Posted on Apr 29, 2013
None of my tail lights work. i changed the bulbs, tail light control board and fuses. I'm an electrician so i need a wire diagram of a 1996 chevy suburban
Your solution is a new combination switch,It also sounds like the hazard are activated and is non operation interfering with the brake light,but either way the solution is a combination swith
Jul 08, 2012 | 1996 Chevrolet Suburban
My tail lights are not working on my 2000 jetta the front lights work the break lights work and the blinkers work all inside lights work just fine
you need new bulbs in tail lights one bulb in each side has two elements one works brake other works running lights the elements in the bulb for tail lites are bad . so just replace bulbs. hope this helps.
Sep 13, 2011 | 2002 Volkswagen Jetta TDI
All my lamp indicator lights keep flashing. blickers work. when you step on break the break lights work. but when driving no tail lights
First replace the tail light bulbs. The tail light and brake lights are different filaments in the same bulb. it is very possible for the tail lights to go out while brake lights still work. And somtimes the tail lights can blow out together.
If you change the bulbs and still dont work then look for other problems.
May 22, 2011 | 1992 Buick Park Avenue
How do I change a brake light bulb in a 1999 c70 volvo?
Welcome to FixYa.com
Brake Lamp Replacement
Location of the lights
The illustration shows the locations of the lights on the RH side. The LH side is the same but
mirror-reversed.
The lights have the following functions:
- 1 +1 = Parking light Fail light
- 2 = Reversing light
- 3 = Fog light LH side only (LHD cars)
- 5 = Direction indicator
- 6 = Brake light
Tail light changing bulbs
Ignition off.
Open the cover in front of the tail light
Undo the wing nut and take out the lamp holder.
Change the defective bulb.
Fit in reverse order.
Check that all bulbs lamps are intact and in working order.
Replacement of tail light cluster
Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
connector for the tail light Undo the four nuts securing the tail light see illustration.
Pull the tail light straight out. Fit in reverse order
Note! check the sealing and fit on reassembly.
Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
Jan 27, 2011 | 1999 Volvo C70
My tail lights dont work or break lights but when i depress the break pedle my cargo break light works...i drive a 02 GMC serrira....my hazards, turn signals, and back up lights work
It sounds like you have burnt out bulbs. All those other lights that you say work are all different bulbs. The tail light bulbs have dual filament so that they can perform the tail light and brake light function. You should change out your bulbs and that will probably solve your problem.
Dec 03, 2010 | 2002 GMC Denali
2001 VW Jetta rear running lights out. bulbs good, fuses good.
Almost sure it is a recall for a relay. Call the dealer, I had a 2001 VR6 with the same problem, and it was a simple, free recall.
May 29, 2009 | 2001 Volkswagen Jetta TDI
Tail light out but break light works on a 2000 yukon
Depend cause you got a running light and another one thats a running like along with brake light.If its the one that has the brake light and the light comes on when you brake and not when you turn on the headlights then you have a bad bulb .Replace that bulb and your set.good luck
May 27, 2009 | 2000 GMC Yukon
All fuses are good, lights bulbs are new whats wrong? but tail light work
check the break light switch it is should be at the top of the brake pedal you can unplug it and jump plug with a paper clip to test if lights work switch is bad
May 27, 2009 | 2000 Toyota Celica
2000 Saturn sl2 tail lights
If the 2000 Saturn SL2 is the same as the '99 SL2, then your tail lights bulb is the same bulb as your break light bulb. Now they are dual bulbs, just like your head lights. So just the same way that your brights can work, but your headlight lamp be out, or vice versa, is the same with your break lights. So replace both bulbs and you should be good to go. I just had to replace both mine, one was a tail light out, and the other's break light was out, either way, same bulb. Also, check your manual for the light, or take the light out when you go in to get new ones. I found that for some reason there is some confusion on the bulb in this make in model.
Feb 20, 2009 | 1999 Saturn SL
Break light problem
Do you know if the brake light bulbs are working? (are the bulbs good?). (the bulbs have two parts, one for brake lights the other for running lights)
If the third brake light bulb is working the brake lights should be with good light bulbs.
Jul 22, 2008 | 2005 Honda Accord
Lands Phones Logo
18 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
