Question about Panasonic PV-27DF64 27 in. TV/DVD Combo
Dvd player Says "This type of disc cannot be played. Please insert a different disc". It says this on all discs I put in. Biblia
  • angeladubois Jan 29, 2009
    I have the same problem and used the lens cleaner as recommended by Panasonic. Still does not play.
  • 91 Answers
It could be that your lens needs to be cleaned
Posted on Aug 10, 2007
  • kimberly puddicombe Aug 10, 2007
    actualy have you tried picking up a cd cleaner
  • kimberly puddicombe Aug 11, 2007
    it is probably not recommending the format of the disc
SOURCE:
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
Dvd player gives message "this
Tries many more DVD discs tries to check it out as the disc u insert in the DVD player tray have difference region format disc that why u getting that answer.
Jun 05, 2011 | Panasonic PV-DM2792 Triple Play 27 in....
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Jul 23, 2009 | Panasonic PV-20DF64 20 in. TV/DVD Combo
DVD no longer reads any discs and won't play.
remove cover of dvd player, than use a cotton swab and rubbing alcohol and clean the lens. if it still doesn't work than I would suggest buying a new one. you can get a decent player for just $30 new
Mar 31, 2009 | Televison & Video
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
SAMSUNG SV-DVD440 Combo
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
Feb 09, 2008 | Samsung SV-DVD440 DVD Player/VCR
Panasonic dvd-cp72
asptroy,
hi mate, just want to know first if what region indicate at the back of your DVD player? the reason why i ask you, is because most of branded DVD have their own region for ex. for asian countries they are tagged as region 3 and Australia region 4 ...... most probably your player is not configured to play multi region disc if it can't play any disc. The only way to check if your player have a problem is to check the region of your player and if you can barrow or buy a dvd disc having the same region. or simply check for DVD disc which indicates that it is a all region compatible. Actually this is only info that i can share, but if your only near in my place i can help you change your dvd player to become a multi disc reader simply by clicking some activation keys using the special remote control specially design to configure and modify region setting of panasonic players.
cheers,
markiez23
Jan 05, 2008 | Panasonic DVD-CP72 Multi-disc DVD Player
Disc playback issues
dvd will not play. display siad "read"
Jan 21, 2007 | Technics DVD-A10 DVD Player
Panasonic PV-27DF64 27 in. TV/DVD Combo Logo
539 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
