Question about Nortel al2012e27 - Baystack 420-24t Switch 24 10100 Base-
Cant connect Baystack 420-24t after factory reset
After factory i cant connect my Baystack 420-24t even console also not connecting is there any way to connect Baystack 420-24t using ip ??
Cant sign into playstation network after factory reset
Doing a factory reset will clear your network settings and sign you out of your account. If you are connected to the internet using wi-fi make sure to get that setup again before trying to sign back into play-station network.
Video:
How to connect ps3 to wifi
Sep 05, 2016 | Sony Playstation 3 (PS3) Console
Cant open the admin console on mt dwl-3200ap
Try this. Push and hold in the rest button while at the same time pull out the powers supply line from the unit. Release the reset and wait 30 seconds. Push in and hold in the reset button, apply power to the unit and keep holding the rest button in for 30 seconds, then let the reset go. It should reset everything back to factory settings and hopefully let you in with the original admin pw when you bought it.
Aug 01, 2014 | D-Link Computers & Internet
My xbox keeps coming up update now but wont do it if u say no it freezes
Check to see if your xbox 360 is connected to the internet. If your xbox is connected to the internet and still is not allowing you to update check your xbox setting. Sometimes your parental control on xbox 360 can stop you from updating your xbox. If all else fails try to take your hard drive off the xbox and reset your console to factory settings
May 29, 2011 | Microsoft Xbox 360 Console
Having trouble with the ethernet connection i can get online but when i connect the 360 to the modem it doesnt recognize the ip address or modem i have tried the reset factory defaults i have tried...
Have you tried manually assigning the xbox a ip address/subnet mask/gateway? You can figure out what range to use by running "ipconfig" from the command line of a windows computer. Just pick a ip address above 200. i.e. 192.168.2.201/255.255.255.0/192.168.2.1
Test that and see what happens.
Mar 24, 2011 | Microsoft Xbox 360 Console
When i click find game for online game at call of duty the console write that connected with matchmaking server and thats it nothing so i cant play online.
Try doing a factory reset on the modem/router, also do a connection test on your PS3 and make sure that your NAT TYPE is 2 anything other than that will give you problems playing online. Let me know if you need help with getting your PS3 to a NAT TYPE 2.
N etwork
A dapter
T ype
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
I cant connect to xbox live when i have done everything it said to in the troubleshooting menu. what else can i do?
.Reset the network settings on your Xbox 360 console to the defaults. Here's how:
  1. On your console, go to My Xbox, and then select System Settings.Select Network Settings
  2. Select Configure Network.Move right on the D-pad to access the Additional Settings tab and select Restore to Factory Defaults. Select Yes, restore to factory defaults when prompted.
    1. Note This will only reset the network settings and not other console settings.
    2. Restart the console.
    3. Go back to My Xbox, and then select System Settings.
    4. Select Network Settings.
    5. Select Test Xbox LIVE Connection.
Dec 28, 2010 | Microsoft Xbox 360 Console
Cant connection to internet but ssid in and do not connection come's up with error code 51330
The error code basically means it cannot establish a connection to the network, like it can't even acquire an IP address.
Aug 26, 2010 | Nintendo Wii Console
Error 8001050f playstation 3
[##[[ There is a worldwide issue with PSN at the moment:
We're aware that many of you are having problems connecting to PSN, and yes, we're looking into it. Stay tuned for updates. about 1 hours ago via web SonyPlayStation''
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
I need a manual for Bay Networks router ae1101008 manual
You can find an installation and operating manual for the Baystack AN systems here.
If you need information on how to connect a BayStack AN platform to a Network, you find that information here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 22, 2009 | NorStar BayStack AN Router
Trying to connect to internet on my sons psp but cant remember the password that was entered,and i cant set up the internet on his psp , testing connection is failing
Go to your Settings, System Settings, and click on Restore default settings. Doing this resets everything to factory settings. Don't worry, it ONLY resets settings. It won't delete anything on your Memory Stick. This feature resets your nicknames, any passwords, and along with Flash player and WMA playback. This will work. When you are done, it will be as if you just got your PSP. Your data will still be intact. However, if you're talking about not knowing the password on your Wi-fi network, then you'll have to contact the provider.
Oct 22, 2009 | Sony PlayStation Portable (PSP) Console
Nortel al2012e27 - Baystack 420-24t Switch 24 10100 Base- Logo
54 people viewed this question
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
