Question about Keurig Special Edition B60 Coffee Maker
Drain inner tank
I tried the suggested advice to hold down the black disk and it would not brew it says prime?
  • 1,511 Answers
Primer defective and needs replacement.
Posted on Jan 30, 2014
When I turn on my Tassimo Coffee maker, the refill water light just flashes, and it won't brew. What can I do? I have tried re-inserting the water tank, cleaning off the barcode sensor, twisting the tank...
I ran into the same problem myself. One possibility is this: Follow this sequence: 1) With the top up and the disk NOT engaged, turn the main power on. 2) Put the disk in and lock the top down. At this time, the cup logo shouls flash once and stay on. 3) Push the large round button once and the cup logo will flash and the brewing should start.
I had a few things out of sequence at first and it was frustrating me as well. I hope this helps!!
Oct 30, 2013 | Braun Tassimo TA1200 Espresso Machine
Tip
Solis Master 5000 is makeing very slow coffee in my cup
Hi
That is usually a pluged or restricted brew head.
That usually means that you are getting a restriction in the brew head from oils and fine coffee grounds.
Remove the brew unit. Holding the handle, on the top left side is the brew head, there is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2 screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk will stay on the spring or crystal ball won't). Do this over a towel to prevent loosing small pieces, mainly the crystal ball if it has one.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers.
Once the screen is out, look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side.
Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first if it had one. Then the spring small end first (black disk in first) on the crystal ball if it had one.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it
on May 07, 2011 | Solis Master 5000 Espresso Machine
Tip
Superautomatic does not make coffee. Wet grounds & pump runs a long time, then...
You have a plugged brew head or bent gate valve. I can help with the brew head but not the gate valve.
Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that is either to the front or back. 2 screws hold it to the top. Remove the 2 screws while holding the manifold ( pipe assembly). Once they are removed, lift the assembly off (be careful, there is an O-ring, spring and at the end, and a black rubber disk or ball that you can loose.
Once the screen is out look at where the screen was. There are 2 holes. A big one in the center and a small one to the side.
Clean then reassemble. Brew unit on towel right side up. Drop the ball in first. Then the spring, small end first on the ball.
Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the direction it came off. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
on Dec 17, 2009 | Coffee Makers & Espresso Machines
Water heats goes back int fill tank instead of the coffee cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 15, 2011 | Keurig B60 Coffee Maker
HOW CAN I GET THE WATER OUT OF THE INNER TANK OF MY KEURIG
You can't. This model does not have a drain, and the water will stay in the inner tank forever!
If you plan on storing the brewer for a length of time, make sure you run several cycles (without k cups) before using it again.
According to Keurig, water remaining in the tank will not damage the brewer nor cause any mold to form due to it's stainless steel inner tank.
Sorry for your troubles, and hope this helps! Happy Brewing!
Jan 07, 2011 | Keurig B60 Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
How empty inner water tank
You must first empty the water reservoir. There is a black disk inside the tank. This disk moves up and down. Place your hand inside the tank and hold the disk up. This will stimulate the tank being "full" of water. Then continue on as if you were brewing a cup of coffee. This will brew the remaining water left in your inner tank. May need to do this twice to ensure all the water is gone. Hope this was helpful.
Jun 22, 2010 | Keurig Platinum B70 Coffee Maker
The liquid coffee isn't coming through. I get wet pellets in the disposal container. The steamer seems to work OK.
Hi Brew head cleaning Vienna/ Master Remove the brew unit. Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door (looks like a long "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (be careful, there is an O-ring, spring and at the end a black rubber disk. Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember, thumbscrew), DON'T use the key to install the screen, use your fingers. Once the screen is out look at where the screen was. There are 2 holes. A big one in the center and a small one to the side. With the brew unit upside down over the towel, insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side. Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ball. Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. That should do it.
Feb 12, 2010 | Saeco Vienna SuperAutomatica Coffee...
Keurig Special Edition B60 Coffee Maker Logo
433 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
