Question about Saws
Silverline jigsaw blade holder
Blade securing device has fell off
2 Suggested Answers
ideaal
  • 1793 Answers
SOURCE: How do i remove a jigsaw blade from the bosch PST 53A jigsaw?
With a long middle size screwdriver
in the hole at the top of the machine http://www.mtmc.co.uk/Bosch-PST-53-A-/-0603229203-Spare-Parts__p-88148.aspx
Posted on Jul 10, 2016
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
The blade broke off inside and I can't get it out. Please help me figure how to get it out.
moden jigsaw blades are held in with a taper chuck system
disconnect the unit from the wall socket
push the spindle all the way in
now press on either side of the blade holder and that should move down releasing the blade
now while holding that section down turn the unit right side up and the broken bit should just fall out
Oct 13, 2015 | Skil 4495-01 6 Amp Orbital Jigsaw
How do i remove the blade on a black and decker U255S Jigsaw
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
Jan 17, 2011 | Black & Decker Black Decker Orbital...
How do you put a blade in a hitachi cj110mv jigsaw
on the front of the saw where the blade is there is going to be a little lever you pull while at the same time push the blade in the blade holder
Jan 16, 2011 | Hitachi CJ110MV D Handle Jigsaw
My Hitachi cj 110 jig saw blade keep falling out I have tried different types of blade What?s the deal with that? I don?t know why someone would put a quick release holder on a blade shaft of a power tool...
WOW everyone really cant figure out the problem??? Take your jigsaw blade and hit it with some coarse sandpaper or a dremel and knock the finish off the edges and sides depending on maker and it willl work just fine. The blade companys put a super slick finish on the blades. not the saws fgault.
Steven Melton
OKC
Jan 09, 2011 | Hitachi CJ110MV D Handle Jigsaw
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
I don't know how to get the blade to stay in.
You have a set screw on the side of the blade holder, usually an allen head, some jig saws have a clamp through the top, a screwdriver down through the top will grab it. Check it out.
Nov 15, 2010 | Makita Jigsaw Blade
Makita 4304T. jigsaw blade Do not know how to fasten it?
On the top of the Makita 4304T is a knob, (Top/Front)
This is the blade Installing Lever.
Viewing the jigsaw in the direction you would use it, the Installing Lever is turned towards the Right. Keeping it turned, you then install the jigsaw blade. Once you have the blade up in the Blade Holder, gently release the Installing Lever.
This is a PDF file of the Owners Manual for the Makita 4304T Jigsaw,
(From Makita - Products - Support)
http://www.makita.com/en-us/Assets/images/Products/4304T/owners_manuals/4304T.pdf
[Should the above direct link not work for you, this is Makita - Products -Support, and the download page,
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=248
Left-click on Owners Manual next to the PDF file Icon]
Nov 04, 2009 | Makita Jigsaw Blade
Change a blade on a jigsaw
They all either have a screw at the side of the blade holder, or some have a hole in the top of the machine where a screwdriver is inserted and a screw loosened to release the blade, and retightened once the new blade is inserted.
Jul 05, 2009 | Makita Jigsaw Blade
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
