Zm 9060 what do all the buttons mean on this a/c remote
I want to program a extra remote to my alarm. What must I do?
You must first provide the year make and model. This process will require a new, cut, "virginized" key. (Virginized simply means the key is not coded to another vehicle already) If you have the key then try searching for the adaptation process on youtube. You can also provide the year make and model here and I should be able to pull the procedure up for you. Its usually something like this, Get in car and close driver side door then, 1. insert old key in ignition and turn on then off. 2. right away put in key you want to program and turn to the on position. 3. After about 25 seconds, open driver side door. 4 turn key off and close door. 5. press and hold the lock button and doors should lock. take key out of ignition and unlock doors. <--- this probably isnt your exact procedure but they are typically similar to this. Please Advise,
-Tim
AutoEcu1
800 921 9060
Feb 03, 2015 | Cars & Trucks
I have a savin 9060 and it is telling me I have an error 92 can u help me??
What do error codes 91 and 92 in the error log mean?
91: The job was reset by the device.
92: The job was manually reset by a user.
Dec 18, 2014 | Savin 9060 Copier With Feed, Finisher,...
Require remote code for lg tv
These are the remote control codes for LG TV: 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Nov 04, 2012 | LG Televison & Video
Cannot fast forward with remote
The solution given above works. But just be aware that the remote "Idalia ZM" is talking about that you press enter + 1 on is your television remote. Fast forward, rewind and skip (both directions) worked after doing this. Thank you Idalia ZM!
Jan 07, 2012 | Samsung DVDC500 Player
Windows 7 drivers for brother mfc 9060
Try this:
http://www.techrepublic.com/software/brother-mfc-9060-5125350-windows/476293
Mar 02, 2011 | Brother International Brother MFC-9060
Product key of ms office 2007
To activate from Office.com/Setup Excel, Word, PowerPoint, and Access:
Click the Microsoft Office Button Click the Microsoft Office Button > Options > Activate Microsoft Office.
To activate from all other Office products:
Click Help > Activate Product.
www Office com Setup Enter *********** 1 888 827 9060
Dec 27, 2010 | Microsoft MS OFFICE 2007 SBE MLK (NA) SW....
I would just like to have the wiring diagram for the Boss AVA 9060 model. Thanks!
wires are: red-ignition, yellow-battery or memory, black-ground, blue-remote for amp or antenna, orange-illumination (if it has one), the white, grey, purple and green wires are the speakers
Sep 17, 2010 | Boss AVA-9060
Philips pd9060, how can i hack to get region free
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Hope this help ! Falcon
Jul 16, 2010 | Philips Televison & Video
Zm-RSSC v2 under
Dear i have send website address of your Windows 7 Ultimate 64x OS and the beta driver for Zalman Tech ZM-RSSC External Sound System.
please follow the instructions and keeps download it.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=3124&Xlang=en_us&Xcntry=USA&source=XOG
Feb 16, 2010 | Zalman Tech ZM-RSSC External Sound System
Problems installing ms office 2007
1.remove your older version ms office give restart & install ms office 2007.
2.your os is sp1 mean install sp2 & install ms office 2007
Mar 01, 2009 | Microsoft MS OFFICE 2007 SBE MLK (NA) SW....
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
