Question about Avanti DG241BS Stainless Steel Gas Kitchen Range
Avanti DG241BS - oven will not stay on
I have an Avanti DG241BS and the stove works fine, however, the oven does not stay lit once you release the knob. Have tried numerous times to hold in the knob at various temperatures and can hear the gas and see the oven ignite, but once I let go of the knob the gas stops. Thought the problem was fixed a month ago, but seems to be back now. The broiler seems to work fine, but have noticed lately it works when it wants (same issue as the oven).
  • 1 more comment
  • Zoobiedoo Sep 17, 2008
    This is definitely a manufacturing problem, as it's occuring with our unit, too. We've attempted three times to have it fixed and no one seems to be able to offer a solution. Deeply regretting having purchased this range.
  • Anonymous Nov 13, 2008
    I, too have this same problem. at first I thought he had to do with the airflow within the oven itself and it was a safety feature- to ensure you didn't just turn on the gas... By opening the door a small amount when 'firing it up' you can draw up the flame a bit and this has helped to keep the oven going, but my results have been inconsistent. Sometimes it works sometimes it doesn't. I also have a problem with uneven heat in the oven and a problem with the ignition- sometimes the flints keep sparking well after I've released the knob...very frustrating.
  • Zoobiedoo Jan 03, 2009
    Same thing happened to me and I'm also very sorry that I purchased this unit for a rental property. Three trips out by the repair person have failed to correct the problem. Stay away from this product if you need an oven that actually functions.
    Scholar:
  • 39 Answers
There has to be a protection system in the burner assembly to cut the supply of gas to the burner if it does not light. For the case of an oven the supply must be cut off immediately if the burner and its pilot go out. For that gas control system to work the burner control must "recognize" with a sensor when the burner is lit and when it is not. Pushing the knob "in" momentarily on this model bypasses the protection system momentarily to allow a burner to be ignited in the first place. If releasing the knob extinguishes the flame the control system is not "seeing" the flame. I tried to find some detail info on you particular ignition system but to no avail so all I can offer is a general approach to these kinds of problems . You need to find and clean or replace the sensor used to detect a flame. It could be an optical one (doubt that) or a temperature flame sensor, a thermocouple sensor, or some other kind I haven't thought of. Fixing this problem involves first determining what kind of sensor it uses. A copy of a service manual for this model can help you determine that. Try to clean the flame detector, and if that doesn't work you have to replace it or the gas control assembly it is a part of. If you have a spark ignition and its not sparking when it should first clean it --carefully--. Spilled food can short them out. Unplug the range before doing this. The owners manual shows it to be under the top burners which can be removed for cleaning this.
Posted on Jan 03, 2009
SOURCE:
Broken stove knob
simple flame sensors at fault eg thermocouples replace bad sensors and dsi box (direct spark ignition )
Apr 01, 2014 | Ovens
Avanti G2002CW oven or broiler won't stay lit once ignited
I had this same issue on this same model (which is how I happened upon this page). I'm still not exactly sure why, but the problem resolved when I pushed down on the knob more firmly than I normally would to light the stove, and it seemed to slide in a little deeper. After that, the oven would light.
Jul 07, 2013 | Avanti Kitchen Ranges
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Ariston gas stove has 2 burners not working
the burner themocouples need replacing...
Dec 21, 2009 | Ariston Technologies Ovens
The dial on my Avanti 24" oven is hard to determine which way to turn. When I hear the clicking sound, as the burners do, next I hear the lighting, whoom. Shall I start it at a low temp and then in a few...
It sounds like you are having an excesive buildup of gas pre-ignition. You should hear no "Whooom" sound.
The ignition assemble likely needs to be cleaned of rust, dirt, grease etc. That is the typical cause if improper ignition, gas buildup pre-ignition etc.
The problem of not staying lit is caused by either the flame sensor not sensing flame, (which may need to be cleaned or replaced.) or that the flame is simply being blown out by the air movement as a result of the sudden combustion of excessive gas build up.
So, to summarize, the ignition and burner assemblies need to be cleaned, and the flame sensor may need to be replaced.
Oct 12, 2009 | Avanti DG241BS Stainless Steel Gas Kitchen...
I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Aug 27, 2009 | Garland H286 Gas Kitchen Range
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Oven will not stay lit
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
hklhlk
Jan 03, 2009 | Avanti DG241BS Stainless Steel Gas Kitchen...
Clicking igniters
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
CALL SERVICE 24/7 HERE,
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 28, 2008 | Avanti DG241BS Stainless Steel Gas Kitchen...
Lighting the oven
I have similar problems with several 20-inch Avanti ranges. Solution(s); Get a new range, different brand. Cool the range between lightings.
Dec 21, 2006 | Avanti DG241BS Stainless Steel Gas Kitchen...
Open Questions:
Avanti DG241BS Stainless Steel Gas Kitchen Range Logo
1,907 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
Shawn DuRee
ray gallant
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
