Question about Dynex 19 in. LCD Flat-Panel HDTV
Dynex 19" other settings/eeprom init missing!
Hi, i have a dynex 19" tv. i have been having trouble with a blue tint ever since i accidentally used autocolor in the factory menu. i have read that it can be fixed by going to other settings and using eeprom init, but i have no "other settings"!
SFroese
  • 141 Answers
SOURCE: dynex 19" tv
Go into the setup screen on the TV and set the channel option to CABLE (it is probably set to AIR right now or something).
The website should also have a manual for how to program the remote.
Posted on Sep 08, 2008
jamielwright
  • 75 Answers
SOURCE: Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Posted on Jun 01, 2009
SOURCE: We have a Dynex 19
After cussing at the thing for a while to get its attention,
I thought the problem over and fixed it as follows:
I went into the setup menu and selected the "reset default option. The set went to blue screen. The next step was to rescan the channels. Then in the time setup menu I turned off the automatic time update. So far have not had any more problems.
Posted on Aug 19, 2009
SOURCE: 19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Posted on Jan 03, 2010
  • 1779 Answers
SOURCE: I bouth the dynex 32" but six months into use I
Either a lose LVDS cable going to the t-con board or a bad t-con board.If it's still under warranty I would take it back for service.
Posted on Dec 01, 2010
My 19 in. is not possible to adjust the color, tint and sharpness bars. It skips, what will I do to make the adjustments?
If the set is running in some type of component mode or digital component mode, there is no adjustment for color or tint.
Sep 21, 2014 | Dynex DX-LCD19-09 19 in. LCD TV
Have red tint in picture
It sounds like the color settings are out of whack, try going to the tv settings and reset them back to default. Then try changing the Red green blue values (RGB) in the color settings, simply lowering the red value might do the trick
Apr 10, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Red tint on the screen an picture
Make sure the signal cable for the input you are using is tight. Possibly try a different cable. Especially if you are using the Red Green Blue component cables. Make sure the issue is across all inputs. If so, try adjusting settings for tint. if that doesn't help you may need to replace the TV.
Apr 09, 2014 | Dynex DX-L32-10A 32" LCD HDTV
Vertical lines half way across screen.
Try performing a factory reset of the TV2_bing.gif. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. If that does not work, send it back for repair. Good luck!
Jan 12, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Red color is completely gone out of the LCD flat screen
You can try performing a factory reset of the TV. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. Good luck!
My new 32 in dynex tv has white squibbly lines on every channel. It was fine last time we used it and now it's not.
Try doing a factory reset of the TV2_bing.gif. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. If that does not work, send it back for repair. Good luck!
Jan 03, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
We have a Dynex 19" television. We use the "timer" function as a wake-up alarm in the morning. The set should turn on at 5:55 AM. Recently the unit stopped turning on automatically. I checked all the...
Aug 03, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Dynex 19" tv
Sep 08, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Monitor color problem
there should be color adjustments in your menu.
also i don't think its the cable if its blue, cuz, if you was miss just blue it would not be blue. and if you had red and green it would not be blue. some video cards have settings to adjust the color in the driver settings or display properties. good luck.
Apr 10, 2008 | Gateway FPD1975W 19" LCD Monitor
Dynex 19 in. LCD Flat-Panel HDTV Logo
71 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
