Question about Dell Audio Players & Recorders
Power supply for dell computer speakers
I recently relocated and am not sure I am usindg the proper power supply for my dell speakers. The plug not not attach properly. The Speakers have a skew of CN-OF6371-48220-555-00HX and the power supply has a skew of 115-0024-001.
  • 29 Answers
SOURCE: Speakers not working, but cables all plugged in...
No drivers for your soundcard, this is a computer issue not a speaker issue, contact dell, if you can understand a word they say, ask them "I have Dimension (model number here), I need to know how to install my sound drivers", if you dont know how to do this.
Posted on Aug 12, 2006
JCinNC
  • 11 Answers
SOURCE: speaker doesnt give sound
Based on the fact that you have put a headset in and another speaker system and it is working properly there is nothing wrong with your windows settings. I would leave them alone. The issue appears to be with the hardware. Have you attempted to plug the speakers into another source (ie. cd player, ipod, etc)? If you plug them in there and they don't work, take the speakers back and have them exchanged. If they're not under warranty you're going to have to either get them fixed or replace them. Good luck on this one! JC
Posted on Sep 30, 2006
SOURCE: Speakers set up properly, but no sound from PC
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer. But there is no sound at all coming out -- just silence.Can You Please Help Me
Posted on Mar 08, 2008
SOURCE: DURABRAND 2.0 CH USB COMPUTER SPEAKERS
I recently purchased Durabrand 2.0 CH USB computer speakers at Wal-Mart. When I hooked them up to my computer all I got was a sound like a scratchy sound. My computer does not have internal speakers and may not have a sound driver installed either. This is a company computer so I can't do alot of downloading. So what or is there a best way for me to get my new speakers up and running.
Posted on Oct 06, 2008
Arius
  • 446 Answers
the problem is your computer may not sense the presence of your audio device, chances are your driver is either corrupted nor not yet installed.
go to my computer then right click go to properties, hardware, device manager,
under the device manager go to sounds and see if ther is any exclamation icon or anything , expand this icon and see if there is anything you see that has a yellow exclamation or question mark right click that icon and select scan for hardware changes , then update driver , better yet go to sound properties and see if you can roll back the driver, if you have the cd utilities for your computer, you can reinstall the driver again and after all this restart once again your computer
cheers
Posted on Nov 08, 2008
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
WILL NOT TURN ON!
Is this a new problem and this ran fine until now? If so, you want to make sure you have power going to the computer, power at power strip or surge protector, cables all plugged in correctly and tight. If all that checks out then the most likely cause is the power supply has failed. If you have had power surges or electrical storms recently this could be the cause. If not, your capacitors in the power supply could just be at the end of their life and died.
Oct 09, 2014 | Dell Inspiron 531s Desktop Computer
Worked great for years. Now, won't turn on. Plugged in and all connections checked. Light at on switch does not turn on.
Next step would be to check for power from the wall wart (external power supply). Note the output voltage indicated on the power supply, then check for that approximate voltage with a multimeter.
A replacement power supply can be found at most electronics retailers. Make sure the polarity matches, ie positive tip or negative tip, and the plug must match dimensionally. Make sure a replacement can supply the current that the original did (rated in milliamps - MA, or amps A). Ideally an exact replacement would be best if that is the issue. Be careful, and don't crack open that power supply!
Mar 07, 2011 | Dell Powered Subwoofer Set A425 Computer...
Hi, we have an Dell PowerEdge 1800 Server, Today we relocated the server for that we shutdown the server and Relocated.When we the Start system nothing is displaying in the monitor. Keyboard light's were...
Most of the systems will not start back when the system shutdown happens due to some power conflicts.
To resolve your issue, please follow the below steps:
1. Make sure that all the connections to your server is proper now.
2. Press and hold the system Power ON Switch in your server for more than 20 seconds continuously.
3. now release the power button and press it back gently once normally to start you machine.
4. In this way most of the system will be powered up.
Please follow the above steps and let me know your comments. If still the problem persists, then please provide some more information about the problem which you got in following the above steps as that will be useful to assist you back.
Thanks
Mar 08, 2010 | Dell PowerEdge 1800 Server
No sound..relocated computer, thought everything is hooked up.
Make sure the speaker wire to the computer is to the lime green plug on the computer and power to speakers and make sure volume control on the computer is not muted
Aug 07, 2009 | HP Compaq WF1907 Monitor
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
Dll user32.dll problem
Certain programs may not start after you install security update 925902 (MS07-017) and security update 928843 (MS07-008) on a computer that is running Microsoft Windows XP with Service Pack 2 (SP2). Additionally, you may receive an error message that resembles the following: application_executable_name - Illegal System DLL Relocation
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\Windows\System32\Hhctrl.ocx occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.
Nov 21, 2008 | Dell Dimension 2400 PC Desktop
I have no sound
Download The Driver from this link and save the file into the desktop :
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R94481&SystemID=DIM_CEL_3000&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=122481
After Download, double Click on the the file and just follow the on screen prompts to install the Driver than restart the computer. If still there is no sound coming out of the speakers. The problem should be on the physical connection of the speakers to the system. Check the speaker connection and make sure the cable is plugged in to the right audio port at the back. If you are not sure where to plug the speaker cable, play a music and try each port. (Make sure that the speaker has power as well - Applicable for speakers with power adapters).
Oct 28, 2008 | Dell Dimension 3000 PC Desktop
No Audio on my desktop
1) Plug the speakers back into the power supply and make sure the power supply is plugged into the back of the speakers.
2) Make sure the speakers are plugged into the PC.
You're vague so I'm doing the best I can here.
Jul 17, 2008 | Dell Dimension 2400 PC Desktop
Dell Speaker 215 problem
Would suggest that when you plugged in the router power supply it supplied a HIGHER voltage and you have blown the speakers.
May 07, 2007 | Dell A215 Computer Speakers
56 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
