Question about Thule 2003 Dodge Dakota - Club cab - Xsporter Truck Rack
ABS and brake lights are on
2003 Dodge Dakota quad cab. The ABS, Brake lights and speedometer where not working. I changes rear ABS sensor on the differential. This fixed the speedometer but it did not fix the abs and brake light problem.
    New Friend:
    Problem Solver:
  • 5 Answers
Either your emergency brake is stuck or you need to bleed brakes. To check the emergency brake pull on it as you pull release.
Posted on Nov 16, 2013
1999 dodge dakota Abs light on and e-brake light on. Speedometer doesn't read untill 25 mph
The speed sensor that controls the speedometer is located in the top of the rear differential housing, this is your most likely problem and is very common with this vehicle. Being that it is a direct input to the ABS module it will cause those indicators to illuminate when the sensor fails.
Feb 05, 2011 | 1999 Dodge Dakota
My speedometer quit working and my antilock brake light is on. I am getting a PO500 code. I replaced the VSS with a new one no change in problem This is on a 2000 Dodge Dakota v-6 automatic 2wd
go to diferential,on center top its posible you find and speed sensor ok if its there,replace it,if it has antilock light on,it has a and antilock sensor problem ok,go to rear axle.
Nov 23, 2009 | 2000 Dodge Dakota Quad Cab
2003 dodge ram 1500 abs & brake light came on. also cruise does not work. any suggestions
Problem: I have a 2004 Dodge Ram 1500 5.7 L HEMI. My ABS and Parking Brake lights were illuminated, and my speedometer needle would "bounce". Also when sitting at a stop sign or just sitting idle, the engine would stall, and often times stop running.
Solution: After long research on this problem, I decided to dig in and try to find the problem myself. I replaced the Rear ABS Sensor
($35) that's located on top of the rear differential. Still no fix. I then unplugged the ABS Controller (or Module) that's located directly behind the battery (You should see the metal brake lines running into the top of it.) When I unplugged it, I noticed LOTS of moisture in the plug. Using an air hose, I blew out the water and let it dry good. When I plugged it back in, and hooked the negative battery terminal back up THE PROBLEM WAS SOLVED!! Simple fix. Hope this helps.
Sep 30, 2009 | Dodge Pickup Cars & Trucks
Dodge Dakota overdrive and ABS/brake problem
The problem could be in your differential. If the ABS traction ring has any defects in the teeth, the rear wheel speed sensor will stop registering and disable your ABS.
This may not resolve your transmission concern, but it may answer your ABS/Brake light problem.
Jun 29, 2009 | 2000 Dodge Dakota Quad Cab
2003 Dodge Dakota lost speedo, reverse lights and ...
It's the speed sensor and it is located on the rear axle.
May 14, 2009 | 2003 Dodge Dakota Club Cab
2002 dodge 1500 sport speedometer or cruise control
The brake and ABS light both come on when you are receiving no speed signal. Most likely the speed sensor in the top of the rearend is bad.
Feb 16, 2009 | 2007 Dodge Ram 1500 Quad Cab Sport
Speedometer dead!
Speed sensor is bad,It is located on the rear axle.
Once replaced,Make sure to reset the computer.
Please rate this a fixya
Feb 11, 2009 | 2000 Dodge Dakota Quad Cab
Replaced rear differential speed sensor related to ABS, Brake Light, speedometer not reading 0-20 MPH, and auto.transmission slippage. Now that I replaced it, auto. transmission shifts without slippage,...
Did you use a mopar sensor.I have fixed this problem many times and not had much luck with the aftermarket sensors.Just a thought.Good Luck!!!
Aug 04, 2008 | 1996 Dodge Dakota
Thule 2003 Dodge Dakota - Club cab - Xsporter Truck Rack Logo
99 people viewed this question
Top Thule Boating Experts
Tom Chichester
Richard Warren
Richard Warren
john cordey
john cordey
Are you a Thule Boating Expert? Answer questions, earn points and help others
