Question about Garden
Cub cadet 1517
Engine does not crank with starting.
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 109 Answers
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Posted on May 03, 2009
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
Shaul Dag
  • 30 Answers
SOURCE: My Cub Cadet LT 1050 will turn over, but will not crank.
Check the fuel filter.
Posted on Jun 20, 2009
wadembly
  • 489 Answers
SOURCE: Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Posted on Jun 28, 2009
Cub cadet 1046 kohler courage lawn tractor cranks but does not start
An internal combustion engine needs three (3) things to run..(assuming all internal parts are good)..
1. A properly timed spark
2. Adequate compression >120psi
3. Proper fuel/air ratio
one of these three (or more) is missing...eliminate them one at a time..(this is the way a professional diagnoses a starting issue)
Sep 17, 2017 | Cub Cadet Garden
Why does the mower blade an a cub cadet 1517 keep kicking out?
check those safety switches. The one under the seat, the one for Reverse and the Brake switch
May 04, 2014 | Garden
Why does the mowe blade on the Cub Cadet 1517 keep kicking out
This is the Dyson section! Please repost in correct section. Thankyou.
May 04, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Cub cadet lt 1042
Some of those cadets (like those with the Command 20) have a compression release mechanism on the cam which is intended to make that engine crank easier but disengages once the engine fires up. It's a plastic part and is prone to break, resulting in a lot of strain on the starter motor. Interesting design, bad materials. Sometimes the engine will start anyway but this is not a good idea to operate this way. Pull the valve cover. Look at the motion of the exhaust valve when you turn the engine by hand. It will look similar to the motion of the intake valve if this part is broken. If it's working correctly, you should see the exhaust valve open slightly just after the intake valve closes. I'll attach a video to show what it looks like. Replacing the bad cam is a bit of work but not terrible.
Oct 04, 2013 | Cub Cadet Garden
Cub cadet 1517
Sounds like there's a problem with the diaphram in the carb. May bet letting to much fuel through which then stalls it.
Jun 27, 2013 | Garden
Cub cadet walking mower, model 959468 can not pull cord to start
there is a the cable that goes to the handle you need to hold that releases the engine brake
Apr 04, 2012 | Cub Cadet Garden
Cub cadet riding mowe
is the mower making any sounds when u crank it or nothing at all?
Feb 07, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
May 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Model SLT1554 PROBLEM: Engine cranks, runs for 1 second then dies. Cranks every time but dies immediately
Sounds like another carburetor blockage. Remove the carburetor and clean out all the orifices in the main jet. Also, check the float for leakage.
Sep 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
