Question about eMachines T6534 PC Desktop
Emachine troubleshooting Machine will not start when push the power switch. Power switch is blinking.
  • 922 Answers
This is typically caused by a power supply failure. Failing power supplies can have enough power to turn on lights and fans but not enough to start the computer. The power supply does not store any data so replacing it is a low risk and low cost effort. It is a very well documented process so search the Internet for "replace power supply" for more details. I hope this helps. Good luck!
Posted on Apr 29, 2013
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Maytag 4000 series MHWE450WW02 has power but when start button pushed shuts off
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Apr 08, 2015 | Maytag Washing Machines
Bizhub copy machine start button blinking
power off the machine using main power switch not the control panel switch
Feb 06, 2014 | Konica Minolta Bizhub 362 Copier
Got a machine but it keeps switching off after few minutes could it be power switch on front if so where can i get one
It isnt the power switch, it's the power supply itself. You need to get a new one from bestbuy.com, Tigerdirect.com or Geeks.com.
Emachines are notorious for their bad power supplies, and they usually burn out the motherboard when they die. Stop pushing that button and get a new Power supply before your board messes up.
Aug 30, 2010 | E-Machines eMachines Desktop PC
Cd brokes in cd rom
IS IT ON?...DOES CDROM HAVE POWER GETTING TO IT FROM PC? Next to open/close switch there is a small pin-hole. Push a paperclip into this hole and gently pull out tray...try gently pushing tray back in and watch for a blinking green light;if none either the cdrom is not getting power, or it has quit working
Mar 20, 2010 | E-Machines emachines (emachinees) CD-ROM...
The power light is on at half light, pushing the power switch has no effect. after removing the power cord and reinstalling it the power supply fan starts but stops. removal of the internal battery and...
I alway regret taking my sister in laws broken E machine.
She had something similar that prevented it to turn on. I was alway wondering it that 3 stem chip at the center of the board was a power on electronic switch When you turn on the machine this little thing would electronically close to complete the circuit.
But I never tooke it and never experimented...
Jul 28, 2009 | E-Machines eMachines Desktop PC
[Emachine C2684] Systems appears to be getting power, but won't boot.
Track down the motherboard manual, the motherboards of branded machines are usually made for them by PCChips or Foxconn or someone similar.
In the manual identify wich connectors on the motherbaord is the front power switch. Disconnect the front power switch and plug it all abck in again to see what happens with the power switch disconnected.
If you feel brave enough you can momentarily short the motherboard powerswitch connectors and the machine will start.
the front power switch is a momentary switch so only short the motherboard pins long enough for the machine to start.
Jul 30, 2008 | E-Machines eMachines Desktop PC
EMachines not powering up
You may have updated windows to a point that this old machine cant handle the revamp. Kick back to an older ops system, although that poses security risks. Your motherboard may also have given up. Best advice - upgrade, and retire this machine to the recycle bin.
Jul 18, 2008 | E-Machines eMachines Desktop PC
E machine
How long does it take for this to happen? Try this:
Click on Start->Control Panel and double click on Power Options. Check the settings on the Power Schemes and Hibernate tabs. You may just need to alter these settings.
If you find this helpful please rate the solution. I don't get paid for this or anything I'm just trying to help.
Jan 01, 2008 | E-Machines eMachines Desktop PC
eMachines T6534 PC Desktop Logo
122 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
