Question about Garden
HOW TO FIX 5HSP WITH NO SPARK
CLEANED MAG AN FLYWHEEL STILL NO SPARK
  • 7,482 Answers
Hi Jerry
If you still have no spark after cleaning the mag and flywheel...then replace the mag...it is faulty
Posted on May 01, 2013
    New Friend:
Or it could be the coil?
Posted on Jun 18, 2013
3.5 Briggs ,new coil ,ground wire unhooked,no spark
Re loosen the magneto place business card between mag. And flywheel retighten mag mounting screws remove business card shine up flywheel with sand paper with the mag off the motor clean rust off flywheel before remounting mag with business card.
Apr 25, 2017 | Briggs Garden
Will the fly wheel cause no spark
Be sure the magneto is gapped properly. A sheared flywheel key will cause timing issues but not eliminate spark. Either you have purchased faulty parts or spark is not your problem. Remove the ground wire from the coil, be sure you have tightened the flywheel nut properly, spray some carb cleaner in the carb and try to start. If it starts on the prime then you have spark and its a fuel problem. If it starts with the ground wire disconnected but not when the wire is connected then there is faulty wiring or a bad switch.
Jul 15, 2014 | Stihl Garden
New coil and still no spark on my GC 160 Honda tiller
Did you check the gap between the magnet on the flywheel an mag? Unplug the stop wire an see how that works. Sometimes the switch is bad. Are the magnets on the flywheel, did you set the gap on the flywheel to mag correctly? Did you do the simple thing an change the plug they go bad more than anything else.
Mar 25, 2014 | Garden
2007 arctic cat no spark
If its under warranty let them do the work. If you have no spark remove plug hold it against engine pull cord an see if you get any spark. If not unplug the ground wire to the mag an watch for spark. Sometimes the secondary on mag fails, another step is replace plug, if that does not solve problem, remove flywheel an check clearance between flywheel an mag. One of these steps will fix the problem. Replace plug first, then check for other problems. More than likely plug is at fault.
Mar 18, 2014 | Toro Snowblower 826 Oxe 38624w With 3 Year...
Have no spark to plugs
Those sensors have no effect on spark. Did you replace the plug, if not remove it hold it against the engine, have someone pull cord, watch for spark. If you have spark then you have a fuel problem. If no spark then after replacing plug, then remove stop wire from magneto side. Pull cord an watch for spark. If no spark then remove housing an flywheel, measure gap between mag an flywheel. Check to make sure magnets are still on flywheel. Call some shop or check a service manual on gap setting. If no spark still you will need to replace the magneto. This is rare an its is more likely a plug that needs replacing. Toro snowblowers are nice machines, this is not a hard fix. Really to tackle this is starting with the plug.
Mar 16, 2014 | Toro Snowblower 826 Oxe 38624w With 3 Year...
No spark on a 126T020675B2 Briggs 6.75 hp mower engine
gap needs to be 10 thousands of a inch done with a brass feeler gauge ..mag/flywheel has a spot with a magnetic field if you look you can see it it should make a 1/2 wrench stick to it if not replace mag/flywheel ..check key way also
Jun 05, 2013 | Mtd 22" Yard Machine Push Mower
Briggs straton 5hp rototiller
Hi Jerry
Check to see if your coil is grounding out...
Here are a few more things to check.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Apr 29, 2013 | Garden
Mtd yardman wont start getting feul no spark detected
if you have no spark check the contact between the flywheel magnet and mag and make sure they are clean and the gap is set ( old school the thickness of a cig. pack) if that doesn't do it check the wire and end for contact. Still no you probably need a new mag
Apr 19, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
What's mag
A mag or magneto is a coil of wire that is "excited" by a permanent magnet thereby inducing a high voltage to fire the spark plug with. Most single cylinder lawnmowers use mag and point systems to fire the plug. Coil is hard mounted and the permanent magnet is part of the flywheel with the points mounted under the flywheel.
A coil is a two coils of wire, one is connected to ground on one end and the other end is connected to either a set of points or an electronic switch, either of which turns on and off the current through that coil. When the coil discharges its electrical potential, its magnetic field collapses, inducing a high voltage in the other coil which is used to fire the spark plug.
Sep 30, 2012 | Generac Rv Generator - 6,500 Watt - 6.5 Kw...
No spark
either your flywheel mag,C.D.I. or the flywheel is dirty(rusted) and mag can't get a good pulse,first check your spark plug and shut off switch if equipped for being defective
Nov 01, 2009 | Honda 8 HP Engine
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
