Question about Refrigerators
253.5470340A need door shelves
Plastic door shelves fall out
Try small cable ties if they sit on pegs sticking out you can then cut the ties for removal.
Aug 26, 2014 | GE 21 cu ft Top-Freezer Refrigerator White...
Fresh food door will not close/seal
Check to see if one of your door shelves is bigger (sticks out more into the fridge) than the other ones. If it is, theses shelves can cause door closing problems. Try removing the shelf from the door and closing it again. If this shelf is the problem, call subzero at 1800 222 7820 and give them your model and serial number, and they will send you a new standard depth shelf to replace the deeper shelf at no charge, these shelves caused a lot of door closing problems when they came out. Hope this helps!
Sep 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Fridge door hinges on right door dipping to the left how do i adjust
First take some weight out of the shelves on the door. To much weight in shelves will make door sag.
Mar 03, 2013 | Zanussi ZX99 / 5 Bottom Freezer...
I need a door shelf for my Frigidaire side by side refrigerator (# FRS6R5ESBFPN # 241691311)
  • You did not list freezer door or refrigerator so I will link you to all of them and you can choose the one you need. These are all for Frigidaire FRS3R5EMB
  1. Upper freezer shelf - http://www.appliancepartspros.com/Appliance-Parts/frigidaire-bin---door-frzr---upper-item-number-ap2115843.aspx
  2. This one is a replacement for the lower 3 freezer shelves http://www.appliancepartspros.com/Appliance-Parts/frigidaire-freezer-door-shelf-item-number-ap2115974.aspx
  3. This one is a replacement for the 2 bottom shelves of you refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2115741.aspx
  4. This part here is for the 2 upper shelves of your refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2116036.aspx
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator door not shutting correctly, not a good seal. could it be the little spring arm at the bottom?
check the gasket around the door,also make sure nothing is hitting on the shelves,if you have to remove some of the food,check the shelves and make sure they are back all the way,i've seen the bottom draws and shelves not in correctly,they stick out farther than they should hitting the door,remove the glass shelves that are on top of the draws and see if the door closes.let me know how you make out
Nov 28, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Hi , my fridge door panel cracked on the side shelving area. what do i need to replace it. is this an expensive process?
depending on the model you can buy an insert for the door which is the shelves and such, just need to replace the shell, about 32 1/4 screws around the edge under the gasket,,,,
if you dont have them, to replace the shell, you would need to buy the entire door.
Oct 02, 2009 | Refrigerators
Whirpool Refrigerator Door Shelves Not Cold Enough
The door bins are the last place you should keep milk. The door shelves are always the warmest part of the fresh food compartment (of any refrigerator). Sorry.
Apr 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door handle coming off
now you just need to buy another handle because the first one is not fixed well, it doen't cost a lot, but when you buy the handle you get free maintenance.
Mar 04, 2008 | GE GSS25JEMWW Side by Side
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
