I need to purchase a new remote for the TV but cannot find a universal remote which will work on anything but the volume and the power button. Can you recommend a remote and the code for the TV?
Do a code search process with your present remote, and see if any code that get by this process will help to activate all the buttons on the remote control. If you wish to get more details, check this site.http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Check the site, and see which brand remote control have setup codes to your TV brand, and buy that one according to availability. Check this site too. http://electrohelponline.blogspot.com/
SOURCE: philips universal remote code for direct tv.
I have a code table for you, you may try this if its different than yours. Here is the direct link (You need Adobe Reader to open it)
Good Luck
SOURCE: Universal remote for Samsung Hitron
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: remote codes
GE ........... 0704 0312 0018 0002 0502
................. 0006 0007 0601 0835 0901
................. 0114 0103 0803 0806 0310
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
SOURCE: Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5.
Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 through 5, trying each
code until you find one that works.
SOURCE: TVTECH Universal Remote (3 Devices)
i got a universal remote it dont have my code in the book i have a durabrand tv do you have any i deal what the code is
