Question about Whirlpool Duet GHW9150P Front Load Washer
F11 code washer locks up
I have a 3 year old whirlpool duet. about halfway through the cycle the washer locks up and shows an f11 code. when we cut off power to the washer for a couple of minutes then turn it on the drain spin cycle it works. this is really aggrevating. these are expensive machines and i expected better. can anyone help.
  • kathie epps Aug 14, 2007
    thanks, i'll give it a try
  • Anonymous Mar 18, 2014
    Meaning for Code F11
The shaking and vibration of the washer makes sense.  I took off the top cover and just pushed on the circuit board connections and the washer instantly worked.  Some of the connections did feel loose and by simply making sure they were connected tightly worked.  Save yourself a service call and try this first.  The circuit board is easy to get to.  Just remove the three screws from the back and the top cover comes right off.  This is for both the f11 and f dl fault codes.
Posted on Oct 14, 2007
  • Nateuofmn Feb 17, 2012
    Ours locked up and wouldn't power on, and without researching we bought a repair plan to get it fixed. 1 minute after that I took off the top and found a loose connection. On the phone now trying to cancel the plan.
  • Douglas Stutz
    Douglas Stutz Feb 26, 2013
    Tried all connections,seem tight. Any other thoughts on that F11 fault?
We've had this problem for about a yr when i finally firgured out how to correct it. the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get. How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Posted on Aug 14, 2007
  • michelpaille
    michelpaille Nov 15, 2012
    Hi patzius1 could you tell me where is the circuit please? Thank you!
    Problem Solver:
I experimented and found that if you set the washer to a different spin speed setting, the washer will complete its cycle. No errors! Cool!
Posted on Oct 06, 2007
Push Start and Stop at the same time and it will unlock the door..
Posted on Dec 24, 2007
SOURCE:
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Whirlpool Duet Sport Model WFW8300SW0 basket won't
    The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
    Hope helps.
    Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
    I keeg getting the dreaded F11 anf DL code!
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    PLACEHOLDER FOR ART
    To remove the error display, press Pause/Cancel twice.
    NOTE: If the error remains on the display, then call for service.
    Take care
    Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
    Error Code F11
    TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
    Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Error code f35 on my washer
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Error Code F11
    its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
    Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet wahsher
    PLACEHOLDER FOR ART
    please do not forget to rate and comment about your experience with fixya today.
    Aug 18, 2008 | Whirlpool Washing Machines
    Whirlpool duet washer
    YA, I HAVE A PROBLEM SAME AS THE OTHERS. AND JUST LIKE THE MANUAL SAYS, YOU ARE SAYING TO CHECK EVERYTHING, BUT YOU WILL NOT TELL US HOW TO CHECK IT, WHAT IT IS SUPPOSE TO SOUND AND LOOK LIKE, WHAT IS NORMAL. SO WE CAN TELL WHAT IS WRONG WITH IT. I DON'T HAVE ALL THIS MONEY TO SPEND ON REPAIR MEN WHO DON'T KNOW WHAT THEY ARE DOING. SO WHAT SHOULD I DO. OH AND P.S. F-28 DOES SHOW UP ON THE WASHER SO IT REALLY IS A ERROR CODE.
    Feb 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Random electrical problems, sometimes it works beautifully, sometimes not!
    F11 = Communication between the Central Control Unit (CCU) and the
    Motor Control Unit (MCU) cannot be sent correctly.
    1. Unplug washer or disconnect power.
    2. Check wire harness connections to the MCU, the motor, and
    Central Control Unit (CCU).
    3. Check the drive system for any worn or failed components.
    4. Plug in washer or reconnect power.
    5. Verify CCU operation by running a Diagnostic test or any
    cycle.
    6. Check the MCU by looking for operations of the drive motor.
    7. Check the drive motor for powered rotations.
    8. Check that the serial harness at the MCU is not mounted
    upside down. The wires should be to the left when facing the
    MCU connectors.
    FDL=
    A Door Lock Error occurs if the door cannot be locked. It will try to lock
    it six times before displaying the error code.
    Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
    porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
    ■ Door lock mechanism is broken or removed from door.
    ■ Door switch/lock unit failure.
    2. Check door switch/lock unit.
    3. Check the wire harness connections to the door
    switch/lock unit and Central Control Unit (CCU).
    Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Duet Washer not working after a year
    F11 means that the motherboard is not talking to the computer that contols the drive motor Fdl is a door lock failure code - i had this exact issue with several and the motherboard resolved it, unfortunately it retails at $324.99
    Sep 28, 2007 | Whirlpool GHW9300 Duet Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    1,882 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
