Question about Gigabyte DVD BURNER GO-W1616A RT (GOW1616A) Burner
My DVD-RW doesen't read CD or DVD
I own a Gygabyte Go-1616A DVD-RW, the problem is that when i try to insert a disc into the driver (DVD or CD) it doesen't read it, i tried installing the latest driver but it still doesen't work ... please help
  • Anonymous Jan 05, 2009
    I hasve the same problem in XP. Not sure if is because of the firmware upgrade I made I made or drivers (Yes drivers!)... of the windows....
    President:
  • 317 Answers
Is this a new drive? Is so, it's probably faulty and you should return it to where you purchased it. If you've used it before, are you using the same kind of discs? Or are the new and different brand? If so, try to get the same kind that worked before. Another thing you should do is clean the drive. You can buy cd drive cleaning kits really cheap.
Posted on Aug 07, 2007
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
PS3 is not reading any discs I insert into the system.
The following types of discs can be played Blue Ray Disc - Playstation No 3 format BD-ROM, BD ROM,BD-R, BD-RE DVD - DVD-ROM, DVD+R/RW, DVD-R/RW, AVCHD, DSD disc CD - Playstation format CD-ROM,CD-DA (Audio CD), CD-R/RW
Also Check the regional code on the disc which should be compatible with the regional codes which can be played by the PS3
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
NEC DVD +RW - 6650A will not read a blank DVD
i ran into this problem a while ago. I had to test different dvd's. I then looked on the manufacturer's website. there they stated which dvd-r, dvd-rw would work. once i tried that brand It worked fine.
Sep 10, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
Drive can not read CDs..read Dvds
I suppose that you have windows XP. Pls follow these steps Clean the disc - Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth. Check the disc for damage - Remove the disc from the drive, and then examine the disc for scratches or cracks. Try a different disc drive - If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. Make sure that the disc is compatible with the drive -Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
  • A DVD disc is incompatible with a standard CD drive.
  • A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
  • A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
Use Windows Update to check for updated drivers - If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.comRegards
Jun 18, 2009 | Computers & Internet
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
NEC DVD-rw Can't read CD disc
You have to download aspi drivers and force aspi18. I had the same problem and this solved it!
Sep 23, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Sony crx320e cannot read cd but can read dvd.
try re-installing the Drive.
Cleaning the Laser head.
Using a different read-write program.
Mike @ Compurepair.
Oct 20, 2007 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Open Questions:
See all Gigabyte DVD BURNER GO-W1616A RT (GOW1616A) Burner Questions
Computers & Internet Logo
106 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Computer Links
steyr1
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
