Question about Whirlpool WMH1163XVS Microwave Oven
Door Open light flashes and relay clicks rapidly
When the door is open the interior light and relay activate off and on rapidly
  • Whirlpool Master
  • 9,085 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, please post a new help request with the full model number from the tag in or on the unit.
Posted on May 03, 2013
  • 37 Answers
SOURCE: Door opener not working
The door latch must have broken in side which had stucked the door does not allow to open. Please arrange to call service engineer from the maufacturer's service center to fix the problem as proper alignment of the latches is must for safety measures.
Posted on Aug 03, 2007
  • 126 Answers
SOURCE: stuck door latch
no call a tech micro-waves can be dangerous to work on
Posted on Dec 22, 2007
reg501
  • 413 Answers
SOURCE: Whirlpool RM278BXP Over the range Microwave
The capacitor and diode will not cause the problem you describe. You will not be able to measure the diode with an ohmmeter, the forward breakdown is about 5-6Vdc. The normal failure mode for the capacitor is a short which will blow the fuse.
If any high voltage components go bad, the microwave will operate normally just not heat.
You should focus on the door interlock switches and safety thermostats, especially the cavity thermostat located somewhere on the top of the cavity.
To make a high voltage diode tester, wire up a 9V battery, LED and a 220 ohm resistor. Hooked up one way the LED will light reverse the connection the LED will not light.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 12, 2008
localwonder
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
  • 119 Answers
SOURCE: Broken door opener button
sounds like the door latch hook is broken you will have to seek a repair man for this
Posted on Feb 13, 2010
When door open light flashes and relays clicking. unplugged and waited reset still does same action
This could be an error code indicating a bad primary door switch, bad cavity thermal protector, or a bad fuse.
It would depend on the brand of oven.
May 28, 2016 | Microwave Ovens
Ge PT 916 wall oven interior light will not go out convection fan does not work I'm thinking it thinks the door is open but I don't see any switch to activate when door is closed any thoughts please
the light will go on and the fan will work regardless of the door position
suggest that you get an electrician in to check the oven electrics
Nov 17, 2015 | GE Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
GE OVER THE RANGE MICROWAVE DOES NOT STOP WORKING
You probably have a shorted cook relay.
We regularly repair this problem with our $39.95 service, or you can order a new circuit board from the Pros here, our favorite supplier.
Nov 27, 2012 | GE SpaceMaker Microwave Ovens
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Have a Panasonic Microwave NN-SA616W, when door is closed looks like touch pad works perfect, but when I open the door start to make a clicking sound and the light starts to function intermittently (like...
There are usually three interlock switches in the door mechanism. One is in the power circuit for the magnetron, one is in the relay drive circuit, and the third is a logic input to the controller. Many times the one in the relay drive circuit turns on the oven lamp when you open the door at the same time it disconnects the magnetron relay. If the lamp relay is stuttering irregularly, that door switch may be going bad.
Another possibility (if this happens only when you open the door while the oven is running) is that the magnetron power door switch is stuck in the on position. This is not a safe condition. Replace that door switch ASAP, and get in the habit of turning off the oven before opening the door.
May 31, 2011 | Panasonic Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
AEG Fault code E202 On opening the door of my microwave combi oven the interior light flashes accompanied by what sounds like a relay chattering and the display flashing between the normal display and...
I would suspect a bad door switch or door switch mount, or possibly a bad electrolytic capacitor on the control circuit board.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Beyond that, I could only speculate, since I don't have experience or information on AEG products.
Jan 09, 2010 | Electrolux Microwave Ovens
Microwave door shut, but interior light is on - micro won't work
Yes. One of your door switches is not working. It could be an alignment issue or a faulty switch. There are actually 3 switches in the door latch area.
Eric
Sep 06, 2009 | Kenmore Microwave Ovens
Microwave buzz with door closed and off This is a GE JVM1443WR Spacesaver... Microwave works, all buttons work, interior light works, and it will heat food... However, even when the microwave is off and...
You can check the relay and related driving circuit. If there is a short in the relay driving circuit there is chance for this type of problem. or the micro processor may be defective.
May 23, 2009 | Microwave Ovens
Whirlpool WMH1163XVS Microwave Oven Logo
512 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
