Question about Toshiba SD-KT50 System
Speaker wires we've lost our speaker wires. where can we purchase five 10' wires for the Toshiba SD-KT50 DVD player (serial # FJJ3902451) ? We live in Chesapeake, VA 23320 area THANK YOU
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
quang123
  • 107 Answers
SOURCE: I want to make my UK DVD player play DVD's from N America.
Try the following procedure
- Power On
- Open Tray
- Press 9879 0 (0 stands for Multiregion, you may press buttons 1 to 6 to choose a specific region)
- A Message appears stating that "The Reg.No was changed to: [insert whatever region (0-6) you selected here]"
Cheers
Posted on Dec 03, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: how to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Posted on Jul 18, 2009
SOURCE: I wish to purchase a Toshiba SD 800 KY DVD player
The machine uses the same code as the SD7200. See the unlock code at this link:
http://www.videohelp.com/dvdhacks/toshiba-sd7200/10068
Posted on Jan 14, 2010
Tip
Toshiba SD-4100 DVD Manual Have you lost your Toshiba SD-4100 DVD Player Owners...
Have you lost your Toshiba SD-4100 DVD Player Owners Manual?
Would you like a digital, searchable version of the users guide?
The pdf version of the Toshiba SD-4100 DVD player is available here.
I hope that helps.
on Apr 10, 2010 | Toshiba SD-4100 DVD Player
Hello, I have had my Home Theate packed for a few years now. I have 2 Toshiba remotes. Neither of them operate the system. One is an SE-R0094 and the other remote is an NB001. I tried new batteries in...
The SE-R0094 is the original remote for the SD-KT50. So should work with it unless it's faulty.
You can get the service manual for the SD-KT50, that might give you clues as to why it doesn't work. It's free the manual, just type the model number into Google.
Jul 06, 2017 | Toshiba SD-KT50 System
I own a Toshiba SD-1200 DVD player but have lost the remote control. Without the remote control it is useless; you cannot play DVDs on it because there's no "Enter" button on the DVD player...
looked around for you couldn't find a new one but i did find one at this link,
http://cgi.ebay.com/Original-TOSHIBA-DVD-Remote-Control-SE-R0030-SD-1200-/400098986865?pt=LH_DefaultDomain_0&hash=item5d27c20b71
Jan 23, 2011 | Toshiba SD-1200 DVD Player
When I put a DVD in the player it gives a "no Disk" message.
I had the SAME problem, and all that was needed was for the laser lens to be cleaned. They have laser lens cleaning discs at Best Buy (that's where I got mine) and probably just about any electronics store that sells/repairs DVD players-- mine cost about $16. You pop it in, it spins and cleans the laser lens, and then your discs are able to be read properly. Hope it helps-- it worked for me!
Sep 06, 2010 | Toshiba SD-KT50 System
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
I need new speaker wires.
So far all I have found is ebay seller that has a set for $40 - still trying to find cheaper solution....
Apr 02, 2010 | Toshiba SD-KT50 Theater System
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | Televison & Video
Remote stolen
Usually pressing the record button a few times will change recording increments on all machines. Some newer universal remotes that have codes for dual dvd/vcr machines will work not older remotes.
Oct 27, 2008 | Toshiba SD-V394 DVD Player/VCR
Toshiba SD-KT50 System Logo
35 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
