Question about RCA P46924 46" Rear Projection Television
46" projection not coming on
All the sudden when you push the power on button there is this terrible static sound and of course nothing happens. The sound continues long as the power button is held down. TV has been great and is built into the wall, so would like to keep it if it can be fixed. Was on high quality surge protector with battery back up and has been tried directly into the wall socket. Thanks!
  • Jim Motley Aug 10, 2007
    Mike,
    Doubled checked and the sound was not coming from the speaker so I did take the back panel off and do see arc flashes of light as you described. Thanks Jim
  • 398 Answers
The P46924 uses the PTK195 series chassis. You do NOT have a power supply or flyback (high voltage) transformer problem. The regulator is the small MOSFET on the heat sink next to the AC power cord. The STK730-010 regulator on a small board above the chassis is the power supply for the convergence. If the STK regulator was bad you would have a picture but the colors would not line up. If the flyback was shorted the set would instantly shut down without making a sound. If the main power supply was not working the set would not even start at all. Is the static sound you hear coming from the speakers, or is it originating down inside the set? Does the static sound like a set that does not have an antenna hooked up or does it sound like a snapping, arcing sound? Try this: Remove the back of the set, dim the lights in the room and have someone press the power button while you look in the back. Do you see flashes of light, like sparks or high voltage arcing? Let me know what you see and hear and we will guide you to the next step.
Posted on Aug 09, 2007
  • Mike Longo
    Mike Longo Aug 11, 2007
    If you see the arcing by the flyback transformer, the kind of whitish-looking "box" at the back of the main board with the thick red wire coming out of the top, then the plastic insulation around the flyback has a pinhole in it allowing the high voltage to leak out. In this case the flyback should be replaced. If the arcing is coming from up around the front of the chassis, then it could be the splitter (distribution) box or one of the anode caps on one the picture tubes which is arcing. Either way, the set should be serviced by a tech experienced in RCA projection sets.
  • 41 Answers
You have an power supply problem & or a high voltage flyback transformer gone bad. The regulator is usually an STK followed by some numbers, located on a separate small board above the main chassis in the rear of the tv. The flyback is down on the main chassis & has a red high voltage lead wire coming out of it that goes to the high voltage/focus block.
Posted on Aug 08, 2007
It won't turn on
I would check the fuse first and if thats good then I would suspect the flyback transformer
Apr 02, 2013 | GE 46GW945 46" Rear Projection Television
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
Mitsubishi 50" (14 yr old tv) rear projection TV
Yes this is the same as the others the voltage regulator is gone on your tv, replace it and take a good look at the power supply and horizontal ckt look for some cold solder
good luck
caypianan@yahoo.com
Oct 29, 2008 | Mitsubishi WT-46807 46" Rear Projection...
RCA P46924 46 in rear projection tv will not turn on
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Jun 02, 2008 | RCA P46924 46" Rear Projection Television
Need help
check your power amplifier I mean the IC for the sound. touch it IF it is very hot its now time to change it of course with the same code.
Jan 25, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
RCA P46924 46" Rear Projection Television Logo
102 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
