Question about Acer TravelMate Computers & Internet
Run diagnostics how do you run diagnostics on this computer? is there a button like f12 or something at boot up?
  • 1 more comment
  • william goertemiller Apr 30, 2013
    computer will not go to the sign on screen. I know that on a Dell if you hit F 12 you can get to the diagnostic menu and find out what is happening but that does not happen with the Acer. Any thoughts?
  • max carson
    max carson Apr 30, 2013
    You can find Documentation and drivers here:http://us.acer.com/ac/en/US/content/driv...
  • max carson
    Have you tried a Systen Restore/Recovery? Can you boot tp safe mode? Does it get to the BIOS setup? Unplug, remove battery, leave battery out, plug in, try to boot to BIOS, Safe Mode, etc. You should unplug after each attempted.
  • Acer Master
  • 7,627 Answers
What are you trying to diagnose? You can run Primary HDD and Memory at boot, is that what you are refering to?
Posted on Apr 29, 2013
3 Suggested Answers
anandsharad
  • 137 Answers
SOURCE: "Diagnostic Boot Selected" problem on power-up boot
its the problem with the keyboard. make sure Function key is not pressed while turning on the computer. normally it happens only then. if the problem presists try reseat the keybaord. to see how to reseat the keyboard.
NOTICE: Disconnect the computer and any attached devices from electrical outlets, and remove any installed batteries.
NOTICE: To avoid ESD, ground yourself by using a wrist grounding strap or by touching an unpainted metal surface on the computer.
  1. Remove the hard drive.
  2. Turn the computer over, and remove the five M2.5 x 12-mm screws labeled "circle K."
  3. Turn the computer over and open the display.
NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Be careful when removing and handling the keyboard.
  1. Remove the center control cover:
  2. Insert a small, flat-blade screwdriver or plastic scribe into the notch at the right end of the center control cover and pry up the cover.
  3. Lift the center control cover up and away from the bottom case.
  4. To release the keyboard from the palm rest, use a small, flat-blade screwdriver or plastic scribe to pry up the right edge of the keyboard near the blank key.
  5. Lift the keyboard straight up about an inch and then rotate it forward toward the front of the computer, until the key face is resting on the palm rest.
NOTICE: Do not pull on the keyboard flex and track stick cables.
Pull up on the keyboard connector to disconnect it from the keyboard interface connector on the system board.
Remove the keyboard from the bottom case
See the images below for ready refference
To repalce the HDD see the image below
I am sure this will fix the computer. Because in this you are reseating the HDD as well. all the best.
Posted on Oct 14, 2009
  • 3940 Answers
SOURCE: i get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
Dell latitude E/6400 blank screen worked yesterday
run the dell diagnostic by turning the laptop on and tapping F12 key when you see the Dell logo
keep pressing F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will beep and display colored bars then ask your if the colored bars were displayed. to press Y for yes and N for no
this test the graphics/video chip on the computer to see if the hardware is working.
You can also connect it to an external monitor like a monitor that comes with a pc.Then press and hold the "FN" key and press the F8 (CRT/LCD) key to toggle the external monitor. if the image is displayed in the monitor then it can be a lcd screen or lcd inverter in laptop.
hope that helps
Feb 27, 2014 | Dell Latitude D630 Intel Core 2 Duo T7250...
Spot screen
Hello
First find an external monitor to test if its the screen on your laptop or the graphics chip in your laptop. If you have an external monitor then hook it up to your laptop and toggle the video over to see if you still see the spot.If it only shows on the laptop screen the Replace the screen.
Another thing you can do is run the built in Diagnostics
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen.
Dec 18, 2013 | Dell Vostro Computers & Internet
Internal hdd hard error
Using the F12 Diagnostics
Nov 19, 2013 | Dell Latitude D610 Laptop Computer -...
Toshiba satellite C655 laptop has black screen with blinking cursor. It did complete some Windows updates. I was on the Internet then my laptop just shut down and it in this black screen with blinking...
Turn the computer off all of the way by holding in the power button until it shuts off.
Turn it back on and immediately start tapping the F8 key. It should bring you to a menu that has an option for going to "Last Known Good Configuration". Choose that option and see if it boots up.
If pressing F8 doesn't bring you to the menu - you may need to run diagnostics on the computer. To get to the diagnostics, attempt to boot to the Boot Menu by pressing F11 or F12 at the boot screen and see if it gives you the option to run diagnostics.
Nov 15, 2011 | Toshiba Computers & Internet
I dropped my dell studio 1735. The battery monitor now displays a red cross even though it does still charge. The machine boots up and runs until I start to do something. As soon as I run any application,...
Hi there! You can try to access Dell's special partition to for diagnostics so you can make sure if there is a hardware problem.
You can access it by Pressing F12 while the computer is booting up, then select boot to utility partition or diagnostics. It will give you an error after that it it founds one.
Hope this helps!
Jun 30, 2011 | Dell Studio 1735 Laptop (NU330)...
Find pre boot diagnostics
When you power up the computer press F1 or F2 or "del" key to enter in bios.There is boot menu .You can diagnostic boot sequence there.
In some computer boot diagnostic come with F8 or TAB or F12.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 27, 2009 | Computers & Internet
I have a dell D820 which will not switch on today, sometimes it gets to the windows XP page sometimes the initial dell page. Other times nothing at all. All worked well last night
immediately run a diagnostics for the hdd alone power on laptop then keep tapping F12 then run the diagnostics. if no errors found then.
try this. power on laptop then keep tapping on F8 to boot options then select last known good configuration. if same problem then boot in F8 then safe mode if still the same problem. use now the OS disc to do startup repair. Boot F12 then select DVD drive in booting make sure the OS media is already on the driver. then just select repair computer then make startup repair. if all fails this might end up reinstalling OS as clean installation.
Oct 21, 2009 | Dell Latitude D820 Notebook
I have a toshiba p205d-s7436 when you turn the laptop on a black sceen reads toshiba leading innovation i tryed putting recovery discs in will not reboot tryed f12 and f2 it will not boot up PLEASE ANY...
The first step is to check the BIOS to see if your hard drive is listed. If so, is it set to be the first boot device. To enter the BIOS, use the F2 option when prompted.
If the hard drive is not present, it's either come loose, or the drive's controller has failed.
Also, if you can use the F12 option to boot to a CD/DVD drive, use another computer to download the Ultimate Boot CD iso from http://ultimatebootcd.com, and then burn it to a CD. This will create a bootable diagnostic CD that you can use to run diagnostics of your hard drive.
Let me know how this works for you.
Sincerely,
James O'Brien
Oct 04, 2009 | Toshiba Computers & Internet
My computer keep on restaritng again ang again....
1st boot to BIOS (F2 at boot) see if system reboots there. If not, the try booting to f12 menu and run diagnostics.
Generally, things like partition corruption, bad RAM and viruses cause uncommanded reboots.
Jul 06, 2009 | Dell Inspiron 1525 Notebook
Dvd r/rw on Dell E1705 laptop computer quit playing cds and dvds. Makes grinding start up noise but does not play
Your system comes with on-board diagnostics. Run the diagnostics to check if the problem is with the drive or windows.
To run the diagnostics follow the steps below
1. Shutdown the system
2. Press the Fn+Power button together
3. The screen will display color screens
4. Follow the prompts until it takes you to advanced diagnostics
5. Do a custom test on the optical drive.
If you are unable to run the diagnostics
1. Find the dell resource cd that came with the system
2. Insert the cd in and restart the computer
3. At the Dell logo screen press the f12 slowly 5 times
4. Select boot from cd/dvd drive
5. Press any key to boot from cd .... message appears press enter
6. If the system starts from the cd .. this would mean the drive is ok
pOst back what were the diagnosis
Thanks
proton
Apr 11, 2009 | Dell Inspiron E1705 Notebook
Computers & Internet Logo
274 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
