Question about LG 32LG30 32 in. LCD HDTV
The menu screen pops up and cycles through the options on its own and I cant get it to stop. Any ideas of how to fix?
    New Friend:
  • 56 Answers
TV is in Demo mode, Acces the menu and turn it off
Posted on Jun 12, 2013
HP Monitor cycling through 'Quick View' menu options and menu buttons are unresponsive.
Your wiring may be causing "cross-talk". Separate the wires in back, so they do not touch. This should be an instant fix.
Dec 28, 2014 | HP w1907 LCD Monitor
How to fix Syncmaster 2494hs touch menu problem?
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
May 11, 2014 | Samsung Computers & Internet
Gemstar perjection screen theater tv after about 10 or 20 min the menu screen pops up and then randomly selecting options repeatedly non stop, how to fix and around how much will it cost?
If the menu pops up at random it likely is the menu button on the set being bad--not the plastic button but the switch under it.
You in USA---? I know two people in St. Louis named Nikki and nick.
what kind of set and what model number?
May 20, 2012 | Televison & Video
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
Apr 04, 2011 | Televison & Video
On the right hand side of montior the is a screen
There might be a tool on your computer about that, you can check the utilities programs on your computer by searching in the Program groups of your Start menu and disable it. Your manual may give you some idea how to disable it. If you right click on that pop up window you might see an option to stop it from popping up. If those are not working, press CTL+ALT+DEL and select the task manager, then kill the process with a similar name. But you don't want to kill too much otherwise other applications may be affected too. Hope that helps.
Jul 09, 2010 | E-Machines eMachines Desktop PC
Menu cycles through the options non-stop
Have you tried unplugging the unit? Sometimes the machine will get caught in a repetitive "cycle" and needs to be re-set. If this does't work, let me know
Feb 21, 2009 | Keurig B50 Coffee Maker
Resolution notice keeps popping up every thirty seconds or so. very annoying. this happens only when using cd rom game diablo. wants me to change to 1280x1024, which my computer is set at now. otherwise...
When you load the splash screen of Diablo enter into settings. Make sure you have the game set to the screen resolution you want.
For the system. Open display properties. Click Settings, click Advanced, click Monitor. (Most games require 60 hertz) to run correctly. Change your monitor to 60 hertz. Than click the Adapter tab. Click list all modes. Move the slide bar to your normal screen res with 60 hertz. Click ok at every screen as you back out od display properties. That should stop your game from popping up.
Feb 26, 2008 | Niko 1920R Monitor
Monitor menu
Hi
Pls go to the monitor menu and reset the settings.
You might find an option Factory Reset or a similar option and once you choose that option, it will reset the monitor settings and tht should fix your problem.
Feb 25, 2008 | Compaq FP 7020 17" Flat Panel LCD Monitor
Menu scrolling and can't stop it
Your set is in DEMO mode......consult owners manual....
Usually in menu pages.........Oh, switch back to English...
select Lingua to change.........T.
Jan 12, 2008 | JVC AV-27432 27" TV
Menu options keeps popping up
Sounds like the button cluster has an issue...see if the menu button is stuck and if not, repair may be needed to disassemble the TV and have a look at the control section.
Jun 07, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
LG 32LG30 32 in. LCD HDTV Logo
134 people viewed this question
