Question about Frigidaire FGQ1442ES Gas Dryer
Lights the lights just seem to trun on with nobody around
  • Official Brand Answer
  • 4,342 Answers
Hi Brian - I understand that your dryer lights are turning on when not being in use. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn on the dryer. Select a normal cycle and verify if the lights continue to flash. If the issue persists, then it could possibly be a communication error with the main control board, or a potential wiring failure or faulty door lock assembly. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Posted on May 01, 2013
My 1994 Firebird 3.4 started having a rough running problem about 8 months ago. It always seemed worse during times of low barometric pressure. It also seems to not show up as quickly if I warm up my
top right side of connector two female spades use paper clip between both connectors. turn key on. see flashing check engine light. three times you will have code 12. one flash, two flash. then codes problems will flash, then repeat. to clear codes, disconnect battery..
Jan 27, 2013 | Cars & Trucks
Panasonic TH50PX80U. When I turn it on the power light stays lit (no blinks) but I have no picture and no sound. Cannot find any info on troubleshooting. Have tried different outlet, same results. Any...
I had the same problem and the only way I could trun the TV off was to unplug it. I took it to a shop and they said it needed a Main board/ A board. They seemed to think that it was a victim of a power surge. The part is around $170 used and $500 new. It is a very rare board so i am still looking for a used one. The part number is TNPH0716ABS.
Aug 05, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Insignia 37 in lcd, trun on light gose blue
It is the main board failure, because Insignia TV has no error blink design.
May 10, 2010 | Televison & Video
I have a problem nobody seems to know the answer to. My daytime running lights get so hot they melt the housing around them. I took it to the dealerhip and they had it all day couldnt find anything. After...
there was a problem with aftermarket bulbs being wrong..check connectors and make sure it has the proper bulbs..see your local dealer for the right bulbs
Dec 22, 2009 | 2004 Chevrolet Malibu Maxx
Trun singles
Assuming that each signal only had two wires, it sounds like you are missing a ground on the side that makes all the lights flash. With 12vdc system, when you are missing a ground, the lights that are missing the ground will use the other lights on the circuit to ground themselves.
Sep 28, 2009 | 2004 Suzuki GS 500 F
Low idol speed
have someone hook up with better scan tool that reads more than code 6
Aug 24, 2009 | 1993 Honda Accord
Psp wont start
Might be the memory card inserted on your psp causing the issue, try to turn on your psp while the memory card is not inserted.
Sep 28, 2008 | Ubi Soft Asphalt: Urban GT 2 for PSP
Esp light stays on and nobody can seem to fix it even audi help!!!!!!!!!!!!!
Got exactly the same problem at the moment. When the ignition is turned off the system resets itself and the light goes out but after a short time of driving it is back on again. Just had the problem diagnosed at a local garage. Apparantly a sensor in the esp system is faulty and needs replacing. Having the job done next week so can't give you any more info only that the sensor costs around £100 plus vat.
Jul 17, 2008 | 2000 Audi TT
Light bulb
I was just looking at these fans. One site said to use the palm of your hand to turn the light cover 1/2 trun. I can't remember which way to turn.
May 16, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Frigidaire FGQ1442ES Gas Dryer Logo
76 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
