Question about Garden
How do i adjust the blade on qualcast e30 mower
  • 420 Answers
SOURCE: how do you set the mower blade height on a riding
The blade height is not adjustable on any of the tractors I have worked on or owned. The blade seats against a shoulder on a spindle and held in place by a nut. Sometimes replacement blades are not shaped the same as the original and changes the blade cuttnig height but other than in those circustances there is no adjustment.
Posted on Jun 18, 2010
heres2maine
  • 84 Answers
SOURCE: how do you change a blade on a qualcast lawn mower
Block the blade with a piece of wood so it stops the motor and blade from turning while your loosening the nut.
Posted on Jul 10, 2010
diodeic
  • 1622 Answers
SOURCE: Have just been given
Yes Go ahead,,But don't apply too much, might makeit to greasy...
Enjoy your new mower...
Posted on May 06, 2011
emissionwiz
  • 78919 Answers
SOURCE: fix a qualcast mower
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Posted on Jul 06, 2012
emissionwiz
  • 78919 Answers
SOURCE: How do I Raise the blades on a Qualcast Concorde
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Posted on Jul 16, 2012
Sharpening blades for qualcast 35s
With a cylinder mower the sharpness of the blade is only part of the concern. The fixed blade is like one of the blades of a pair of shears and each "blade" of the revolving cylinder acts as the other.
As long as only grass is being cut (no stones) the blades will last a long time with only occasional adjustment to the fixed blade as per instruction manual.
After much use or in case of damage the fixed blade will need replacing or sharpening. If it is badly worn it will need removing and sharpening by a specialist with the correct equipment but otherwise the light application of a file, stone or a patent sharpener and then readjust the blade per manual.
When eventually the cylinder becomes worn or sustains damage it must be removed and machine trued and sharpened using a lathe or similar.
An accurately sharpened cylinder and a true and sharp fixed blade correctly adjusted will consistently cut paper across the complete width of the blade when turned by hand. A competently sharped and adjusted cylinder mower will cut the thinnest tissue like the finest scissors without binding.
Aug 18, 2016 | Health & Beauty
How do I fix the drive for blade on qualcast 4000 electriclawnmower
When you start mower does the motor run. If so you may have broken the safety pin in the blade adapter drive that the blade is bolted on. if so you have to take the blade off and the blade adapter. that the blade is bolted on and there should be a groove on the drive shaft that the adapter slides on. The safety pin goes in the blade adapter.
Apr 24, 2016 | Garden
How do you higher or lower the blades of qualcast hover mower
There are not any levers or anything to adjust blade height.
You change blade height by placing spacers above and/or below the blade. You have to remove the blade and relocate the spacers on the blade bolt to move the blade up or down.
Jul 01, 2014 | Garden
Qualcast rm34 assembly
I'm not familiar with the Qualcast rm34 assembly, BUT... from the "smoke" from beneath, I suspect that something has jammed/locked the blades, or blade pulleys, and the resulting slippage of the belt is causing the smoke.
With engine off, AND the spark plug wire FAR REMOVED from the spark plug, CLEAN OUT ALL DEBRIS FROM beneath the deck, above deck, AND from all areas in contact with the belt!
May 04, 2014 | Garden
Fix a qualcast mower
Jul 06, 2012 | Cars & Trucks
I have a qualcast 35s petrol lawnmower and i cant stop the blades going round when i start it it on tick over, it allways seem to be driven
Hi, first of all I would check that the cutting cylinder is correctly adjusted, i,e, just kissing the bottom blade.dont forget to re-adjust the chain. next i would remove the four engine mounting bolts and slide the engine away from the clutch drum so that you can check if the clutch shoes are binding on the spindles, if the spindles are rusty centrifugal force will throw the shoes outward to engage the drum but the springs wont be able pull the shoes back.try wd40 on the pins while trying GENTLY to revolve the shoe round the pin, hope this helps
Sep 12, 2009 | Garden
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
