Question about HP OfficeJet 7310 All-In-One InkJet Printer
Officejet 7310 HP
When sending a fax while feeding it into machine I hear a loud hum and fax stops. I get power failure report that it was not completed because of power failure. It prints fine and receives and copies also. Just will not fax makes loud spining/humming noise.
  • 6 more comments
  • David Oppegard Aug 13, 2007
    Did not work. The fax still had the hum and fail to work. Receipt said power failure.
  • Anonymous Apr 24, 2008
    I have the exact some problem.
  • heyoak Apr 27, 2008
    I am getting a scanner failure when I try to fax. First it happened when I used the paper feeder, now it happens when I place a document on the glass. I can print or copy but the scanner 'jams' as soon as I try to fax. It reports it as a power failure. This just started happening in the last few weeks, it worked fine before that.
  • ralucas Jul 26, 2008
    When trying to send a fax directly from the 7310 printer I get a loud noise and the error message "scanner or power failure, turn power off and turn on." However, I can send a fax from the 7310 glass by going through the HP Director software on the computer and all other functions of the printer work flawlessly.  I have been in email contact with HP tech support but as usual, these towel heads obviously know less than I do because they just keep running me in circles and will not answer any questions I ask them.  Has anyone else had this problem??
    [email protected]
  • Anonymous Jan 21, 2009
    Once I hit start fax black, the feeder takes the first page about 20% in to feeder and then stops, makes screeching noise and reads "error scanner failure" turn power off, then on.
    Aftewr turning power off, then on, it spits out a failed fax page.
    Uggggh!
  • joeVS Feb 05, 2009
    I have the same problem. Problem is mainly when using the fax feeder, but sometimes when faxing from the glass. Also happens sometimes, but not always, when enlarging images being copied. There is a loud whirr noise, and then failure. If faxing, I get an error message that says to turn off power, then a fax page complaining of power failure. The whirring noise sounds like a belt is slipping and then something is free spinning inside the machine. This appears to me to be mechanical, not in the electronics. I'm tempted to try to open the machine and clean things, but don't want to permantly wrecj whatever printer function I still have. Printer works fine. Incoming fax works fine. Most copy functions work fine. It mainly outgoing fax and enlargements that cause the problem.
  • Anonymous Mar 25, 2009
    same problem!!!!!!
  • bluevalley1 Apr 15, 2009
    same problem.
    last time after 3 months of BS by the hp company they replaced it. This is the second machine that is doing this same thing! I only fax about once a week, and keep things cleaned. wth? any ideas?
    President:
  • 317 Answers
Follow the steps below to perform a fax diagnostics test. 1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide. 2. Make sure you have inserted the print cartridges and loaded paper before starting the test. 3. Press Setup, 6, and then 6. This displays the Tools menu and then select Run Fax Test. The HP all-in-one displays the status of the test on the color graphics display and prints a report. 4. Review the report. * If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems. * If the test fails, review the report for more information on how to fix any problems found. 5. After you pick up the fax report from the all-in-one, press OK. Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test. If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
Posted on Aug 07, 2007
Try to scan and it dons't do not thing it said that i need to install
hp software for this feature but i have install everything that
came with the pakage
Posted on Jul 17, 2008
SOURCE:
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Dec 05, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Error
You should be able to send out a fax on there without replacing the cartridge.
Jul 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Whizzzzzing sound and will not send fax.
The problem is the power supply try to plug to different outlet and then send a fax if it fails then its a power supply fault please change it.............
May 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Hp officejet 7310 fax problem
Just change below settings
Press setup on the all in one. Navigate to Advanced Fax Setup using arrow key. Set the FAX Speed to Slow and turn off the ECM (Error Correction Mode). Try sending fax. Please simply send a fax (single page black and white text) (1-888-473-2963 . Check for the result.
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJect 7310 Uses 2 Pieces of Paper when Printing Fax
Sounds like the feed rollers need to be cleaned or replaced.
Dec 03, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
OfficeJet 7310 FAX issue
Did anything happen prior to the issue? It almost sounds as if the DC controller (main board) has gone bad. What happens if you try to make a copy on it?
May 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
751 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
