Question about Huffy 20 Green Machine Bike
Huffy green machine 20"
Pedals slip
2 Suggested Answers
  • 21 Answers
SOURCE: remove the pedals from a boys huffy bike
Bike pedals can be a little tricky, but most likely for that bike you will need a 9/16's wrench. There should be some flat surfaces inboard of the pedals between the crank arm (the long arm that you screw the pedals into). Now, here's the hard part - the R pedal is normally threaded, but the L pedal is reversed. The easiest way to remember which way to turn the wrench is to stand behind the rear wheel and you will always pull the wrench towards you to loosen. Depending on how long the pedals have been on, they might be pretty tough to get off. You could use some penetrating spray (like Liquid Wrench) and let that sit for awhile. Also, once you get the pedals off, remember to put a little grease on the threads so that next time they won't be so tough!.
Posted on May 14, 2010
Adjusting the brake on 20" huffy green machine
RIGHT AND LEFT ITS ALL THE SAME,
YOUR RIGHT HAND BREAK HAS A NUT RIGHT TOP FRONT
YOU TURN RIGHT TO ADJUST YOUR BREAKS TURN LEFT
TO LOOSEN BREAK.
D,R,CLAUDIO
Aug 18, 2017 | Huffy Cycling
Where can I buy the 2 1/2 3/8th bolt with a washer and a nut to fix the rearend of green machine. The threads are worn off and can't find the washer or nut. the rear tires fell off.
Hi Linda:
You should be able to get the supplies you need at any hardware store. Example here in Canada........ Canadian Tire /Home Hardware / Home depot /. Lordco
Cheers
May 16, 2016 | Huffy 20 Green Machine Bike
How do you adjust the brakes when assembling ?
if you are having a problem with the brakes,then you need to get control over your legs,there is no brake,it is a three wheeler,operated by the front wheel, Huffy Green Machine Owner Manual Page 20
May 23, 2015 | Huffy Bikes Green Machine Tri-Wheel...
How to put together the 20' huffy green machine
There should have been instructions to complete this task in the box. If you didn't get them, lost them or never had them, I suggest (a) go to Huffy.com/customer service or support or (b) take the bike to your nearest bike shop for correct and complete assembly.
Oct 15, 2014 | Cycling
I need instruction manual for green machine. How do I download it?
One way would be to use a search engine "huffy green machine manual"
Aug 31, 2011 | Huffy Cycling
What is the size of the thread of a standard bike pedal?
There are 2 standard sizes:
Standard one-piece cranks 1/2" x 20 tpi
Standard 3-piece cranks 9/16" x 20 tpi.
The Right Pedal (gear side) has a normal thread, the Left has a reverse thread.
Dec 21, 2010 | Huffy Pro Thunder Boys 16-Inch BMX Bike
My son has the Huffy rock out bike. The pedal fell off, and so I was sent the whole single arm crank and new pedals. I have no owners manual, and no assembly instructions whatsoever. Along with the crank...
The reason the pedal fell of is because of a bad set up. Who assembled the bike? If, you did, guess what! You did not tighten the pedal to the crank arm to begin with. If, Walmart or other discount store did it, have them fix it. You have to understand. you bought the bike without professionals putting it together and sometimes that is a problem when you don't have the knowledge of what you are doing. You have to pay one way or another. When you let a kid ride a bike that is not assembled correctly you are endangering them. My advice is :Get it fixed right.
Sep 16, 2010 | Huffy Cycling
Pedal arm stripped and pedal will not screw in.
You Can go to www.huffybikes.com to order a new crank arm and pedal, go to the Support and than go to Missing a Part
Jun 13, 2010 | Huffy Girls Bike (20")
The pedal came of my daughter's bike. How do I
the left side pedal is a left hand thread, turn it anticlockwise to install, Right side pedals are RHT turn clockwise
Apr 26, 2010 | Huffy 20 In. Girls Celebration Single...
Huffy 20 Green Machine Bike Logo
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
