Question about Ariens Lawn Tractor 46"" Riding Lawn Mower 936053"
Briggs wont start
Cranks but wont start,has good fire on both plugs,i cleaned the carb.... and the fueltank?
  • Ariens Master
  • 7,482 Answers
Hi Rudy
Sounds like you still have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 30, 2013
2 Suggested Answers
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
Posted on May 30, 2010
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
Cranks and fires but wont strats
Hi Anonymous, sounds like you have a fuel pronlem. Check fuel flow to carb, check fuel filter remove air cleaner and squirt starter fluid or Brake Kleen into carb throat, if it fires up and runs for a few seconds then you have a carb problem. Remove carb and bowl clean clogged jets and air passages, and clean bowl. Visit website below to download cheap ( $5.50 ) service manual that will walk you through it and also trouble shoot:
Harley Davidson Manuals Mark Workshop
Good luck
Apr 04, 2014 | 1979 Harley Davidson XLS 1000
Toro wheel horse 15-44hxl wont start
What motor do you have. Briggs & Stratton motors are notorious for the valves getting out of adjustment. When this happens they frequently develop a tight spot that is very hard for the small batteries and starters to push past. This often results in this sort of condition. Sometimes you can help it by jumping it off another battery to boost the cranking power, however it's best to get the valves into proper adjustment. If you have good connections and have ensure that your starter is getting enough power, make sure you have spark by pulling your plug (the motor should crank well even if valves are out for a spark test, it shouldn't hurt anything doing it). If you have spark and all else is well, check the valves. If they are right, you may need to re-clean the carb if you still can't get it to fire, focus on making sure the idle jet is clean. Also make sure it hasn't fallen out. These jets are tiny and can EASILY fall out of the carb and disappear unnoticed when you remove the fuel bowl to clean it. (speaking from painful, embarrassing experience)
May 07, 2013 | Garden
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Yard Machines 13.5 HP riding mower wont start. It turns over fast, has good spark, good gas, good filter, clean carb, just wont fire. It ran fine yesterday and i parked it last night and tried to fire it...
Hi, check that the choke is operating and make sure the plug is wet after cranking. If so replace the sparkplug as it may be breaking down under compression. Also make sure it has compression ad it may have a stuck valve. regards Phil
Jun 19, 2012 | Yard Machines 155 Torque Briggs Stratton...
26 hp briggs it is firing and full of fresh gas but wont start.
Well you didn't indicate what its mounted on but the basics are: spark and fuel. Pull a spark plug and make sure you get spark. If you do then it must be fuel. You can try a shot of starting fluid (small amont) into the carb, if it runs on that you know you have a fuel problem. Be sure the carb is getting fuel from the tank. Clean the carb. Maybe a carb kit. With today's fuel, you must take care of your fuel system. Use Sta-bil year round. Fuel can go bad in 60 days.
Jul 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
17.5 briggs intek backfiring thru carb wont start have adjusted valves?
Easy things to check, flywheel key, make sure it is not broken, check the coil gap to the flywheel. could be the coil is not advancing. Check, if it has one, the oil sensor by unplugging it. hope this helps.
Apr 14, 2010 | Parks Optical 13.5hp Briggs And Stratton...
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Ariens Lawn Tractor 46"" Riding Lawn Mower 936053" Logo
82 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
